No start, no crank, one click
2006 DX 90k miles, automatic
Randomly would not start since about December 2019. Fiance described it as, "it just did nothing when I turned the key but would start the second or third time I tried it".
Last week it stopped starting, battery voltage is 12.6, load test is good, turn key and you hear a click from starter. It is one single click and nothing else.
I was in the car when this happened, I heard the starter try to turn maybe once then stop. After that, dead, only one click from starter when the key is turned to start.
I have already bought a new starter but I have been reading that it could be many other causes. I have eliminated the key security possibility. I was planning to check the relay in position 7 in the relay box under the hood.
Aside from this does anyone have a recommendation as to whether this sounds like a bad starter? Is this common?
Thanks in advance
Thanks in advance
Re: No start, no crank, one click
I would guess bad starter, maybe a bad connection.
Try smacking the starter and see if it will start
I replaced the relay under the dash just in case but it didn’t work. However, I kept on cranking and there was a burnt smell. I guess the starter definitely needs replacing. 👎
No, you'll have to check the ignition switch, start relay and all associated wiring.
https://youtu.be/2RUhq7sXNBo
Josh Phillips
Jan 12, 2018 07:45 PM
civic_mechanic
Feb 21, 2017 07:48 PM
jimwe
Feb 6, 2013 10:28 PM
xylerium
Oct 31, 2011 09:32 AM
breault5
Dec 30, 2007 12:34 PM
