wont shift out of 2nd gear
Old Apr 14, 2019
crystalsky93's Avatar
crystalsky93 is an unknown quantity at this point
i have a 2000 honda civic ex coupe and i just changed the transmission fluid when i take off driving it will go from 1st to second gear but it will not shift out of 2nd to 3rd or 4th what could be my problem? ( I JUST CHANGED THE TRANSMISSION FLUID ECT)
Old Apr 15, 2019
Colin42's Avatar
Re: wont shift out of 2nd gear
check your shift linkage
Old Apr 15, 2019
where is that located at this is the first time i have ever owned any kind of car
Old Apr 15, 2019
Colin42's Avatar
the big metal bars that run underneath the car from the shifter to the trans.
could also be broken inside the trans
Old Apr 16, 2019
mac25's Avatar
Dr Krieger of Modification
You changed it or a shop?
Was OEM honda ATF used?
Was it drain and filled or was it force flushed?
Any issues before the fluid change?
Is you're ATF fluid on full? (Remember to check it with the engine off, on flat ground)
Old Apr 16, 2019
Car has automatic trans, yes? (just a wildass guess it's not a manual trans)
It already had these problems before you changed trans fluid?
You changed fluid, hoping those problems would go away?
Fluid level is too low? Too high?
Do you know the correct way to check trans fluid level? (trans fluid hot, engine must be OFF, check within a minute of turning engine off, etc)
If a shop did the work, what did they say when you took the car back for them to double check their work?
Did you demonstrate the issue to them?
You shifted but went too far past D?
Car has how many miles?
Got fault codes?
Old May 8, 2019
qball's Avatar
qball is an unknown quantity at this point
Crystal, still there? Wondering if your problem was resolved. Like the last reply, I'm thinking this is an automatic, no? If miles are high and fluid rarely/never changed, changing it can actually cause malfunction.
Shrader335
Transmission
Jun 29, 2020 09:04 PM
Jdm1011
Sep 8, 2017 10:00 PM
06HondaCivicSi
15
Jan 20, 2015 10:39 AM
vtecskeeter
Jun 18, 2014 07:13 PM
