wont shift out of 2nd gear
Rep Power: 0 wont shift out of 2nd gear
i have a 2000 honda civic ex coupe and i just changed the transmission fluid when i take off driving it will go from 1st to second gear but it will not shift out of 2nd to 3rd or 4th what could be my problem? ( I JUST CHANGED THE TRANSMISSION FLUID ECT)
Received 1,131 Likes
Rep Power: 192 Re: wont shift out of 2nd gear
the big metal bars that run underneath the car from the shifter to the trans.
could also be broken inside the trans
Dr Krieger of Modification
You changed it or a shop?
Was OEM honda ATF used?
Was it drain and filled or was it force flushed?
Any issues before the fluid change?
Is you're ATF fluid on full? (Remember to check it with the engine off, on flat ground)
It already had these problems before you changed trans fluid?
You changed fluid, hoping those problems would go away?
Fluid level is too low? Too high?
Do you know the correct way to check trans fluid level? (trans fluid hot, engine must be OFF, check within a minute of turning engine off, etc)
If a shop did the work, what did they say when you took the car back for them to double check their work?
Did you demonstrate the issue to them?
You shifted but went too far past D?
Car has how many miles?
Got fault codes?
Crystal, still there? Wondering if your problem was resolved. Like the last reply, I'm thinking this is an automatic, no? If miles are high and fluid rarely/never changed, changing it can actually cause malfunction.
Jdm1011
09-08-2017 10:00 PM
06HondaCivicSi
15
01-20-2015 10:39 AM
vtecskeeter
06-18-2014 07:13 PM
