Key stuck between 0 and I, stuck in Park. Can't remove the key
Old Dec 19, 2014
tolgaek's Avatar
tolgaek is an unknown quantity at this point
I have a '03 Civic LX. Recently my key was becoming a pain in the butt to turn, I would have to slowly pressure it to turn as I inserted the key into the ignition.
Last night, when I turned the car off, the key got stuck just between 0 and I and now it's stuck there (even though it jiggles) I jiggled it for hours and I can't turn it to 0.
I tried removing the battery after reading on here that it might be something electrical but it didn't do it.
Basically:
- Key stuck between 0 and 1
- Can't change gears, firmly stuck in P
- Wheel is not locked and I can turn it quite a bit and it doesn't lock
- Made sure I jiggled the gear shift to make sure it doesn't think it's not at P (although this might be the case)
Can anyone help?
Old Dec 19, 2014
mikey1's Avatar
Re: Key stuck between 0 and I, stuck in Park. Can't remove the key
can you turn it the other way and start the engine again? then turn the steering wheel and try to remove it?
Old Dec 19, 2014
First thoughts
Interlock issue, solenoid and lever isn't allowing cylinder to rotate
Or
tumbler issue, lock cylinder needs rebuilt.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
hondadude
23
Jun 11, 2002 06:22 PM
