Need some Help... Gauge Cluster Light Turns off when parking lights come on...
Old Apr 14, 2009
kingofheartz's Avatar
kingofheartz will become famous soon enoughkingofheartz will become famous soon enough
Whenever I turn my head lights on, the gauge cluster lights totally turn off. It is not because of the dimmer dial, that is on max setting. I have noticed that even on max setting the gauge cluster is especially dim with the headlights off. Then when i toggle the headlights on, the gauge cluster completely goes dark.
I have went through and checked all the wires to make sure they are all in tight.
any ideas?
PS. I have done a 02-03 gauge cluster conversion but this is the first time i have been having this problem.
Old Apr 14, 2009
CraigW's Avatar
Re: Need some Help... Gauge Cluster Light Turns off when parking lights come on...
My 05 has 2 brightness settings... 1 when the lights are off 1 when the lights are on. Try turning the **** when the lights are on.
Old Apr 14, 2009
thanks, i just tried it. they are both on max settings =(
Old Apr 14, 2009
CraigW's Avatar
Is this the cluster assembly using the LEDs for backlight illumination ??
The cluster night illumination was working fine... and then quit ??
Old Apr 14, 2009
yea, the led works very faintly until i turn on the parking/head lights. it happened about 1 week ago. up until then it has been very bright.
Old Apr 14, 2009
its possible the leds are dead, or the PWM circuit they use for dimming them. its full bright normally. i havent heard of these clusters failing cause of the big circuit board acting as a heatsink, but i guess its possible. how many cluster miles?
Old Apr 14, 2009
29k cluster miles. i think ill go back and check the connections a little bit later. maybe I am missing a loose wire or something.
Old Apr 14, 2009
just realized that my climate control does not light up either but the bottom buttons with recirculate, ac, and defrost come on and dim with the headlights on. is it possible that the climate control is shorting out the gauge cluster?
Old Apr 14, 2009
possibly a loose power wire to the cluster. but im not sure why dash lights would be affected.
Old Apr 15, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
I remember on my 02 civic when i had the old gauges in (01 02 style) the speedo had a brightness **** that when you turn it the gauge would dim and the interior lights would dim with it. (ex when speedo is dim, the PRNDD2 would dim as well) It seems to me like you have a loose wire in your cluster causing your interior lights to dim
trellex
May 24, 2015 04:39 PM
Ma213802
May 18, 2015 07:01 AM
werdnahall
May 17, 2015 11:37 AM
eXNBP
Dec 9, 2001 12:32 AM
wawacito
Nov 5, 2001 03:32 PM
