Suspension advice
Suspension advice
Hello everyone, first post on civicforums.
I hope you guys can answer my question(s) or criticize with whatever i'm doing is good or not.
So first off i researched right when i got the car on what suspensions i want.
I drive a civic 2000 EX Sedan
For my car, i was thinking about getting Ground control coil over sleeves(350/380Lbs), with Koni yellow shocks.
Then getting Function 7's lcas.
Last, a 22/23 mm sway bar+ASR brace kit(pacakge)
anyone know if thats a good rate for canyon running+dd?? And, can anyone help me convert it to kg?(can't find how to do it).
Also, why is it better to have a stiffer rear than front for spring rates, anyone tell me?
Will I need to buy anything extra to install those into my stock car?
Last, do i need to take ANY specification when i get these installed to my car?
As much help and advice will be best, noobie at work, so educate me!! thanks in advance
Re: Suspension advice
Get the springs, the LCA's are useless, and wait on the sway bars and braces till you can figure out how your car handels on the new suspension and then adjust from there. Buying more parts isnt gong to make your ride better, in fact, slapping on whatever parts you can afford will probably just make handling the car even worse with your driving style.
another import thing, have you thought about what tires you want to run??
2002ExCivic
22
Sep 28, 2015 08:29 AM
