searching for a intake manifold 50 civic ex
Old Jan 25, 2007
ST8RACE's Avatar
ST8RACE has a spectacular aura aboutST8RACE has a spectacular aura aboutST8RACE has a spectacular aura about
i have been searching for a replacement intake manifold for my d17a2
im installing a turbo kit and looking to replace the plastic factory manifold. what are some of the members doing with boosted vehicles . thank you .
Old Jan 25, 2007
familycar's Avatar
custom or d16y8 with the injector plate from the d17 I/m welded to the y8 runners
Old Jan 25, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
b20 intake mani with the b20 runners welded to the original d17 intake mani flange with a k20 throttle body
ive got an extra d17 intake mani for sale if you want to try some stuff without ruining yours. 35 shipped.
Old Jan 25, 2007
familycar's Avatar
lol there are like 3 b20 manifolds. there is the high rise, then what your used to seeing the lowrise, and also a b18b obdI mani on the b20. i have 2 of them. either way its going to be a bit of fab work to make it fit. if its a f/I set up you may as well go with the d16y8 for the ease of install. its also one of the best flowing stock mani's made by honda
Old Jan 25, 2007
Civicman1988's Avatar
custom build my own intake manifold form scratch for my D17A2
Old Jan 25, 2007
Old Jan 25, 2007
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
Nice work. That back plate that attaches to the D17 injector plate, did u have that machined by a CNC shop? nice welding aswell.
Old Jan 25, 2007
bought it from a member supermex has one if ur interested. thanks man took me 3 years to learn how to weld like that
Old Jan 25, 2007
drunkenmagnum's Avatar
good work! i have seen supermex's in person and it was awsome. how much to make me 1?
Old Jan 25, 2007
BCCentaur3's Avatar
BCCentaur3 is an unknown quantity at this point
Nice work man. Yeah I would like to know too, how much?
Old Jan 26, 2007
familycar's Avatar
nice civicman, i see you chose to go boosted instead on N/A
Old Jan 26, 2007
i have over 300 hours into it not even joking all the tubes i had to sand by hand thats where almost all the time came in and thre a big *** spacer that i made where the throttle body comes onto. cost me around 50.00. I had to get a special bit to cut which was 20.00 and 30.00 for aluminum. Can' t wait to get it on
Old Jan 29, 2007
familycar's Avatar
so your going boosted now?? that manifold wont be good for a N/A application
Old Jan 29, 2007
burke420's Avatar
The World Is Yours!
nice work!
Old Jan 29, 2007
why you say that?
Old Jan 29, 2007
Originally Posted by burke420
nice work!
thanks
Old Jan 29, 2007
but u still didnt say how much
Old Jan 29, 2007
Dmowerz34's Avatar
Dmowerz34 has a little shameless behaviour in the past
ill pay 450 for a custom one
Old Jan 30, 2007
familycar's Avatar
why you say that?
unless you put baffles inside to smooth out the transitions for higher velocity its going to cause you a power loss. if you look at all the custom manifols the boosted guys are having built youll see what i mean. it looks exactly the same. a forced induction manifold need to flow volume so the transitions dont need to be so smooth, it just need to be able to hold a higher volume. a N/A maifold need to be able to flow air smoothly for the highest velocity not volume. here are a couple of articles i just searched for real quick that should help you understand what i am talking about.
first one explains velocity and volume and how it effects power:
Ideas: Flow Velocity, Flow Capacity, Flow Quality - Team Integra
this one explains different designs:
Intake Manifold Tech: Runner Size Calculations - Team Integra
I hope this helps shed some light on the subject and will keep people aware that building manifolds isnt just making one look pretty. the design of the manifold will greatly effect power
Old Jan 30, 2007
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Very nice article.
God job family car
Old Jan 30, 2007
supermex's Avatar
Very nice, informative, helpfull article.
God job family car
Old Jan 30, 2007
i do have baffles in there and all the corners are angled. I made it to go btoh ways becasue i putttin it on for now and maybe doing turbo seeing how much money i will have to do a set up. supermex what size tubing do u have since u have the mustang throttle body
Old Jan 30, 2007
familycar's Avatar
i do have baffles in there and all the angles are corned. I made it to go btoh ways becasue i putttin it on for now and maybe doing turbo seeing how much money i will have to do a set up. supermex what size tubing do u have since u have the mustang throttle body
the larg square plenum design isnt good for flow. you would need to shape the entire inside for velocity. Good N/A I/M's spend countless hours on a flow bench. These motors like longer intake runners stock. what you have is ideal for a boosted car though. dont get me wrong. its just not going to provide you with the same benefit while N/A. it will take away from your top end after the volume of air it holds is used, because it will not flow at a high enough velocity to keep the plenum full. with air being forced in to it there is no need to worry about how fast air is being drawn in because it pressurized.
take a look at this manifold. i have never see anything like it. i was pretty impressed. i think it would be good for either application.
Name:	Custom Intake.jpg
Old Jan 30, 2007
if you have seen the way it is set up inside its just just like a round tube the square corners are not square i just like the square look. i did my research it can go either way
Old Jan 31, 2007
familycar's Avatar
good job then. I wish you had some pics of the inside for me..
usually manfiolds arent good for both type of aspiration. but with the correct baffling and fabrication its defnately possible..
+rep for you for doing such a good job and being such a good welder lol
Old Jan 31, 2007
familycar's Avatar
well it says i must spread some love around before giving it to you again
Old Jan 31, 2007
the runners look square but there not i made them out of 3 inch aluminum round stock and i shave them down on the top and bottom to loose some weight adn they got in the way of the injectors. i will try to get some inside shots but i am finishing fab on a bracket for it so its not here and then it off to get polished but i will get you those pictures.
Old Feb 1, 2007
familycar's Avatar
please do i would love to see what you came up with as far as baffling. you lay good beads man. i cant wait to see the rest of the work
Old Feb 1, 2007
ya thanks three years of learning to weld tig is very hard but cant give up
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Civic4ever1996
Apr 16, 2015 08:30 PM
Hobby2K
Nov 9, 2001 04:08 PM
viper775
Nov 8, 2001 09:14 PM
skywalker
Nov 8, 2001 05:04 PM
