Emanage help
Emanage help
OK ill rep anyone that helps me on this. This isnt hard but to make a long story short some ******* broke into my car and stole my radio along with it the emanage. So i just got in the emanage and i mostly got it all connected but one thing. It didnt come wiht a sensor harness...... sooo i have to use mines which was ripped out so it dosent have the clip. Can someone tell me which pin goes where? ill just put it in manually and ducktape it on or something until i get my new sensor harness. Thanks in advance.
i did, they didnt write up which wire goes to the sensor. Im not sure people get what i need. On the sensor harness to the emanage should be a yellow clip for you to plug in the emanage. I dont have that cuz they ripped it out. So i just have the wires in there and i am plaaning on just plugging those wires in without the clip. BUT i dont know which wire goes to which.
Im trying to contact greddy but there not responding my emails =.=
your answer should be in one of the first 5 links here Greddy - Founded and Driven by Racers
its not there if it was i wouldnt have posted this thread. can someone help me take a picture of the sensor harness clip with the wire exposed on the clip i just need to know which is the black, white and red wire need to go on the harness TO the emanage not the ecu
are the wires hooked to ur car? did they just rip the lil black clip that the wires go into and then go into the unit off? id call there tech line even though they are never much help and ask which wire goes in which PIN hole. most likely.....they are going to tell u to buy another harness....as for the trouble ur going to go thru to fix it and the potential ur going to have for them poping out of the clip when u hit a bump and really screw things up. ur better off buying new harness and cutting the harness in half and sautering the wires together in the middle of the harness to ur end of the harness
opto_isolator
Engine Swaps
17
Jun 13, 2005 10:04 PM
