Emanage help
Old Jan 8, 2007
AznChinksta's Avatar
AznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really niceAznChinksta is just really nice
Emanage help
OK ill rep anyone that helps me on this. This isnt hard but to make a long story short some ******* broke into my car and stole my radio along with it the emanage. So i just got in the emanage and i mostly got it all connected but one thing. It didnt come wiht a sensor harness...... sooo i have to use mines which was ripped out so it dosent have the clip. Can someone tell me which pin goes where? ill just put it in manually and ducktape it on or something until i get my new sensor harness. Thanks in advance.
Old Jan 9, 2007
plz help bump
Old Jan 9, 2007
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
email greedy and ask them as where witch wire goes to.
That would get you started.
Old Jan 9, 2007
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
check the tech chat/diy section... there is a whole write up on emanage DIY with all the wiring schematics etc. hope this helped you
Old Jan 9, 2007
i did, they didnt write up which wire goes to the sensor. Im not sure people get what i need. On the sensor harness to the emanage should be a yellow clip for you to plug in the emanage. I dont have that cuz they ripped it out. So i just have the wires in there and i am plaaning on just plugging those wires in without the clip. BUT i dont know which wire goes to which.
Im trying to contact greddy but there not responding my emails =.=
Old Jan 9, 2007
TRIZ's Avatar
your answer should be in one of the first 5 links here Greddy - Founded and Driven by Racers
Old Jan 9, 2007
its not there if it was i wouldnt have posted this thread. can someone help me take a picture of the sensor harness clip with the wire exposed on the clip i just need to know which is the black, white and red wire need to go on the harness TO the emanage not the ecu
Old Jan 21, 2007
C2i0v0i1C's Avatar
SuperMODrizd
are the wires hooked to ur car? did they just rip the lil black clip that the wires go into and then go into the unit off? id call there tech line even though they are never much help and ask which wire goes in which PIN hole. most likely.....they are going to tell u to buy another harness....as for the trouble ur going to go thru to fix it and the potential ur going to have for them poping out of the clip when u hit a bump and really screw things up. ur better off buying new harness and cutting the harness in half and sautering the wires together in the middle of the harness to ur end of the harness
dezod
Engine Management
112
Feb 7, 2008 12:38 PM
MadWheel
Bolt-on Engine Performance
May 15, 2004 09:55 AM
chesireCAT
Engine Swaps
Mar 2, 2004 07:29 PM
Ahtasham
Engine Swaps
Mar 2, 2004 11:01 AM
