Suspension experts help plz!!!
Old Aug 5, 2005
manthatguysfast's Avatar
How many pots have you smoken?
manthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of lightmanthatguysfast is a glorious beacon of light
I've searched the susp. forum and I can't find anybody who has had similar problems I am having.
First - im dropped on neuspeed sports springs on stock shocks and riding on 18s.
my problem is that when Im making a turn, even at normal speeds, my car looses traction and bounces a lot! what confuses me is that the ride isn't that bad when im going straight, i mean its a bit harsh cuz of the 18s on a 35 series tire and stock shocks - but its not that bad. but when i make a turn it feels like the car slides out... /... this way. meaning during the turn i feel the back of the car slide just a bit.i really dont know how to explain it more than that. its just really bouncy during turns.
my question is what is the cause of this? could it be because my tires are near done with? could it be because im on stock shocks? i was also thinking a sway bar might help!
please help i have no idea about suspension performance!
Old Aug 5, 2005
IDQcivic's Avatar
IDQcivic should not be trusted
Yeah upgrade your suspension and that might help, I would get a set of full coilovers, and front/rear sway bars...
Old Aug 5, 2005
FALKEN's Avatar
Civicforums Junkie
1) SHOCKS
the stock shocks/struts arent helping your situation...
swap them out for something better
2) TIRES
are your tires worn out?
are they not the proper tire for your needs?
3) SWAYBARS
if the rear-end is 'sliding-out' in the turns, you have oversteer...
swap the rear swaybar for something smaller OR swap the front swaybar for something bigger
Old Aug 5, 2005
Zzyzx's Avatar
Autocross Junky
Its your shocks... The OEM dampers are bairly able to handle the OEM springs.
People seem to not realize how big a role dampers make in the whole performance pacage of a car.... they influence cornering, ride quality, braking, acceleration and general safety.
Old Aug 5, 2005
Originally Posted by FALKEN
1) SHOCKS
2) TIRES
3) SWAYBARS
swap the rear swaybar for something smaller OR swap the front swaybar for something bigger.
I may be completely wrong, but i don't think its oversteer. i think the slideing feeling i get is more because the of the bounciness. feels like my tires are slipping out from under the car lol. i drew a high quality picture to illustrate what i feel when going around a turn. take a look...
Old Aug 5, 2005
Zzyzx's Avatar
Autocross Junky
which one of these is happining. (BTW, unstableness in a turn, particularly if the car gets unstable in a bumpy turn, is almost allways a damper issue)
Old Aug 5, 2005
sorta like this. that car i erased was doing something crazy with the wheels lol.
Old Aug 5, 2005
Zzyzx's Avatar
Autocross Junky
So the car is oversteering... but any way Pick up a set of dampers. (may as well resolve the 1st problem)
Old Aug 5, 2005
let the flames begin....
whats the cheapest set of GOOD dampers that i could can get? preferably a set that comes assembled..top mount and everything..
Old Aug 5, 2005
Zzyzx's Avatar
Autocross Junky
Pick up some Tokico HP's. probably the cheepest ones that will handle those springs.
And your not going to find ANY damper that comes pre-assembled. only way to find that is to get a pre-built "coilover".
Old Aug 5, 2005
whoops - i was thinking damper = true coilover?
i want to get a full coilover that replaces shock/strut/spring.
if i get B&Gs its just a complete replacement right? so the install would be the same as changing the springs, meaning i would take the old shock/strut out - and instead of meessing with springs id just put the B&G coilver to replace the OEM, correct?
Old Aug 5, 2005
Zzyzx's Avatar
Autocross Junky
More or less, but then why spend the extra $$$ when all you need is a decent set of dampers?
Old Aug 5, 2005
im not happy with my neuspeed sports. they sqeak and crack all the time and the back is lower than the front. also, i want something with a really good ride quality. not to mention that i don't want to mess with having to modify my stock stuff to get them to work.
i was just about to edit my last post to ask about Megan Coilovers. those are direct replacements, correct? and they would give me a near stock ride comfort, right?
Old Aug 5, 2005
TeLLy's Avatar
Yes, it's an Acura EL
My Megans dropped right in, no modification necessary. In fact, they even came with their own top mount bolts. Bonus.
No coilover kit will give you anything close to near-stock ride comfort. In fact, I'm of the opinion that no aftermarket suspension spring/coilover combo will be comparable to stock comfort. My Megans, set at 3 short of softest setting, are still good and stiff, but you feel every little dip or crack in the road. I'd go as far as to say I'd be able to stop on a dime cause I'd feel the car going over the damn coin. You get used to it, it's part of having an aftermarket suspension. If you want stock comfort, the only way is to stay stock.
Old Aug 5, 2005
so the ride wouldn't be any better if i got the Megan coilovers vs if i just bought a set of HPs?
Old Aug 5, 2005
Zzyzx's Avatar
Autocross Junky
It would probably be better with your neuspeed springs and Hp's, given that the springs are progressive rated rather then Liniar (whats on the Megans)
BTW, the saggy rear end you have now, may be a symptom of blown shocks....
Old Aug 5, 2005
is there a different coilover besides megans that have progressive spring rates?
i just looked at the DIY for the koni inserts - and i THINK the tokicos would be the same thing right? i REALLY don't wanna do all that haha.
Old Aug 5, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
well, Koni's are.... inserts and involve cutting.... Tokico's are full replacement. The Neuspeeds are good springs! it really isnt a good idea to buy a coil-over set and then find out you dont like them.
btw: non progressive springs ride almost like you have no suspension (ie: how a bicycle feels).... every bump feels rough.
Old Aug 5, 2005
oh is that right? the tokicos are full replacements? meaning i would load the neuspeed on right on them?
Old Aug 5, 2005
i'm pretty sure that is how it is... I'm 100% there is no cutting.
Old Aug 5, 2005
FALKEN's Avatar
Civicforums Junkie
yes.
Old Aug 6, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
Did they ever start making the tokicos for 03-up civic sedan? Last time I checked I couldn't find them.
Tedverseti
Apr 23, 2020 01:45 PM
Solo Flow
Oct 4, 2015 07:52 AM
Tedverseti
Sep 29, 2015 05:41 PM
Luluharp
Sep 27, 2015 11:56 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
