extend the O2 sensor wire
Old Apr 6, 2005
Hayz's Avatar
Exclamation extend the O2 sensor wire
AND I DID SEARCH no answer
I live in chattoonga TN and they just started Emissions Testing last month what my problem is that i won't pass right now because i have a Kamikaze header which means no Catalytic Converter going to 2.25 custom exhaust piping with a 2.25-Vibrant proformance Stainless Steel Resonator what i'm wanting to do is remove the Resonator and replace it with a Magnaflow 53000 Round Series Catalytic Converter because my Resonator is right by the downpipe but i'll need to extend the O2 sensor wire... ok so my question is if i extend the wire will it still give a good signal to the OBD system?
heres pics of my setup
Name:	exhaust pipe 1.JPG
Old Apr 6, 2005
Hayz's Avatar
no help....
Old Apr 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
I see no reason why you couldnt assuming that you make good proper connections of the wire extensions. Ive seen O2 sensor wire extensions before but i cant recall where or who made them
Old Apr 6, 2005
Hayz's Avatar
well i got a Mil Eliminator from bigjoshracing.com and i've had it about a year works great but the instructions that came with it said whatever you do "don't cut or alter the two white wires" so i thought that it might send a bad code to the OBD or somthin
Old Apr 6, 2005
skipbarber's Avatar
do one of two things. Buy the longer EX O2 sensor at www.hondaautomotiveparts.com it's like $40. Or extend your current one, make quality connections, preferably solder them and keep the wires as far away as possible from heat. As long as you don't start the car with the wires cut, I don't see why it would throw a code.
Old Apr 6, 2005
strtrcr656's Avatar
strtrcr656 is an unknown quantity at this point
Cool OBX Header
I have an obx 4-1 header on my car and i extended the o2 wires as for a better fit. So far no problems what-so-ever.
Old Apr 6, 2005
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
as long as u solder and tape them ull be ok
Old Apr 7, 2005
joshb_'s Avatar
Boosted 04
joshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nicejoshb_ is just really nice
Use the metal clips the crush down on each wire and have the hole in the middle, then solder that and put shrink wrap on it and the signal should be fine.. Your not really adding that much resistance with a few inches of wire.
Old Apr 7, 2005
Hayz's Avatar
Thanks! to everyone who posted, i'll be doin it next week and the Emissions Test month so i hope i pass
Old Apr 7, 2005
joshb_'s Avatar
Boosted 04
Rep the ppl that helped!!! hahaha
geforce789
Aug 19, 2015 06:17 AM
acjones21
Jun 9, 2005 04:30 PM
MiamiUgen7
Bolt-on Engine Performance
Apr 5, 2005 01:51 PM
low04
Feb 28, 2005 07:29 PM
SDE
Mar 30, 2003 03:56 AM
