oil cooler?
Old Jun 6, 2008
dust's Avatar
dust is an unknown quantity at this point
oil cooler?
turbo guys what oil cooler u guys recommend. something small since i am running stuffing all this stuff in the engine bay.
Old Jun 6, 2008
andyman97's Avatar
Turbo Guru
Re: oil cooler?
Earl's 19 row.
Old Jun 6, 2008
MrXclusivE's Avatar
MrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of lightMrXclusivE is a glorious beacon of light
Re: oil cooler?
Just be careful, you'll have a noticeable drop in the oil pressure if you run a cooler setup, make sure you do it right.
Old Jun 7, 2008
andyman97's Avatar
Turbo Guru
Re: oil cooler?
No you won't. You'll have an increase from cooler temps. Hence the purpose of the cooler. Cooler oil = more viscous = better pressure in hot conditions.
Old Jun 7, 2008
speedfoos's Avatar
Re: oil cooler?
You got that parts list for me yet?
Old Jun 7, 2008
andyman97's Avatar
Turbo Guru
Re: oil cooler?
Yeah, but it's at work...sorry, been busy, haven't even had time to order my own ****.
Old Jun 7, 2008
Boilermaker1's Avatar
Jap-Euro Fusion
Re: oil cooler?
The entire system floods, the pressure doesnt drop unless you seriously mis-size the lines. -10 lines work just fine, my oil pressure drop is less than 1 psi.
I'm using the little earls cooler and it works more than adequately. Dont want to go to low though.... you want the oil to be around 210 degrees hot.
Old Jun 7, 2008
Hey GUys 41's Avatar
Hey GUys 41 will become famous soon enough
Re: oil cooler?
Best way to do it, is to have one with a thermostat to regulate the cooling, but those are pricey.. in the several hundred $ range.
Old Jun 8, 2008
emjay's Avatar
emjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the roughemjay is a jewel in the rough
Re: oil cooler?
how much is the one u guys recommend?? should i get one?
Old Jun 8, 2008
andyman97's Avatar
Turbo Guru
Re: oil cooler?
Exactly. Earl's makes a nice one that fits like a sandwich plate adapter and it's barely over $100. It's not a bad ideal for anyone going turbo, they help out alot.
Old Jun 9, 2008
speedfoos's Avatar
Re: oil cooler?
Summit has the inline thermostats for oil coolers for like $26. Page 142 of the spring catalog.
carid
Nov 7, 2015 01:46 AM
SidCivic
17
Aug 23, 2015 03:14 AM
adamdrives
15
Aug 8, 2015 08:53 PM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
