EPS problem...help
Old Aug 2, 2007
D5cIvIc's Avatar
EPS problem...help
hey guys,
I have a k20a2 swapped into my EM2. I have a little problem with my ep3 EPS conversion on my car. The EPS unit came off an 04 civic SI, just for clarification.
When i start my car, the EPS is as smooth as butter. It will stay smooth until i drive the car for approx. 7-10 min. then the EPS will get weaker.
The power steering is still there, but A LOT weaker. Its gets to a point where the power of the EPS is right between NOT having power steering and having the EPS run smoothly.
Does any know what could be wrong? i checked the wiring and it seems good. Bad control box? bad rack? anything please help me out. I love to drive it when the EPS is running at 100%.
Old Aug 2, 2007
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
Re: EPS problem...help
u check the fluids?
motor going bad/weak?
Old Aug 2, 2007
D5cIvIc's Avatar
Originally Posted by xproductionz
u check the fluids?
what fluids are you referring to exactly? THe motor is not weak, the motor is strong and healthy, to my knowledge. No CEL no nothing.
As in fluids, all the fliuids are filled, but not sure what the fliuds have to do with the electronic power steering though.
Any other suggestions xproductionz?
Old Aug 2, 2007
well the motor is probably strong at first then getting weak after.. thats the only thing i can think of.. u think about it theres not much things can cause it to feel weak..
Old Aug 2, 2007
bigfish2007's Avatar
bigfish2007 is an unknown quantity at this point
power steering fluid.
Also doesn't power steering have something to do with a belt?
Old Aug 2, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
EPS = Electric power stearing, there are no fluids, just grease.
Is your motor over heating on the EPS wrack when its slowing down?
Old Aug 2, 2007
djmota's Avatar
sounds like the motor is overheating and getting weak. is the any exhaust piping close to the motor?
Old Aug 3, 2007
D5cIvIc's Avatar
disregard this post, the whole time i thought you guys were talking about my actual K20a2 motor, but now that i've read it again, you guys meant my electric motor of the EPS.
Old Aug 3, 2007
D5cIvIc's Avatar
deleted post
Old Aug 3, 2007
D5cIvIc's Avatar
deleted post
Old Aug 3, 2007
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
im not an expert by any means but sayings as its electrical could it be a voltage problem? i duno just a thought no idea how the eps works though.. sorry probably a waste of time..
Old Aug 3, 2007
D5cIvIc's Avatar
well there's only one exhaust piping near the rack and that's the stock header/cat. Can't really relocate those away from the rack.
I know of 2 other em2 with the same set up and theirs run fine.
I think the electric motor might be going out, but wanted to see if i could find something else that could of been wrong with it that's easier for me to replace.
Old Aug 3, 2007
D5cIvIc's Avatar
ok part 11 is what i think i should be replacing. I actually bought the eps off a member on k20a.org let me see if he can do anything about this for me.
Do you guys have any other suggestions about how i can pinpoint this problem?
Like how exactly do i know if the motor is overheating? by the feel of touch?
Old Aug 7, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Check small stuff first such as grounding points. Do you have enough?
Check your alternator and battery... make sure they are in good condition. Other than that, it could be a defective EPS motor.
Old Aug 8, 2007
D5cIvIc's Avatar
I think i have enough ground already. Where did you place ur grounding points? my battery is a brand new optima red top and the alterator seems to be working fine..i think. I'll try to recheck everything i can before i purchase a new eps motor. thanks nameless.
Old Jun 17, 2011
sikandersharma's Avatar
sikandersharma is an unknown quantity at this point
my eps LIGHT STARTS FLICKERING OVER 3500 RPM AND WHEN I TURN ac ON IT GOES OFF. IT IS ALSO GOOD WHEN HEAD LIGHTS ARE ON AND EVEN REAR DEMISTER HELPS TO TURN IT OFF. EPS STOPS WORKING WHEN LIGHT IS ON. ANY HELP?
Old Jun 18, 2011
sl33pyriceboi's Avatar
this is a five year old thread. you should make your own thread if u want a better response to your problem.
google = search power overload.
Old Oct 26, 2022
poeljw's Avatar
poeljw is an unknown quantity at this point
I have something similar going on with my civic... did you ever remedy this?
Old Oct 26, 2022
Colin42's Avatar
Did you even read the post you quoted?
Old Oct 26, 2022
poeljw's Avatar
yes... why?
Old Oct 26, 2022
Originally Posted by poeljw
yes... why?
read the post you quoted - he did not have the issue...
Old Oct 27, 2022
poeljw's Avatar
attn: sikandersharma or anyone else...
Did you ever manage to remedy this EPS problem? I'm having the same issue and it also seems to settle down when I switch on the rear window defrost.
Old Oct 27, 2022
poeljw's Avatar
I quoted the wrong post... I just reposted... thanks...
army12bc
May 23, 2010 09:52 PM
kc8ktq
Oct 14, 2009 03:54 PM
civic-king
Feb 24, 2009 04:42 PM
quick silver
Dec 16, 2007 07:18 PM
gelshmoff
Feb 18, 2007 10:44 PM
