ES1 C101 pinout needed
Hello everyone, I need a pinout for C101 connector (this large white plug behind the glovebox that connects the engine harness to the chassis harness) for the 04-05 Civic LX Sedan, although I think it is the same for all the 04-05 Civic 1.7's and I would greatly appreciate any diagrams you can provide as I am only able to find a diagram for the 01-03 Civic. I am currently prepping for a K24 swap and I need this diagram to repin the K20 engine harness to work in my Civic. Thank you very much in advance!
Last edited by D17VTECPOWER; Feb 1, 2021 at 05:23 PM. Reason: picture did not post correctly
Re: ES1 C101 pinout needed
There's also a stickied thread with a download for the factory manual with all the wiring diagrams....
Hi, Could you, please send that diagram for the 01-03 Civic, for the C101 connector?
Thank You.
I just have listed the colours:
NOTE: The numbering was given arbitrarily dued to the fact that presently I do
not have any other information.
The half side (01 to 10) has a plastic connector holder attached.
Female side
-01
-02
-03
-04
-05
06-blk/2wht
07-blk/2wht
08-yel/2red
09-yel/2blk
10-blk/2wht
-11
-12
-13
14-grn/2wht
15-yel
slot
16-wht/2grn
17-grn
-18
19-red/2wht
-20
Male side
-01
-02
-03
-04
-05
06-blk/2wht
07-blk/2brn**
08-yel/2red
09-yel/2blk
10-blk/2wht
-11
-12
-13
14-grn**
15-yel
slot
16-blu/2wht**
17-grn/2wht**
-18
19-red/2wht
-20
Take care.
Volcom.
Thank You.
Female side
-01
-02
-03
-04
-05
06-blk/2wht
07-blk/2wht
08-yel/2red
09-yel/2blk
10-blk/2wht
-11
-12
-13
14-grn/2wht
15-yel
slot
16-wht/2grn
17-grn
-18
19-red/2wht
-20
Male side
-01
-02
-03
-04
-05
06-blk/2wht
07-blk/2brn**
08-yel/2red
09-yel/2blk
10-blk/2wht
-11
-12
-13
14-grn**
15-yel
slot
16-blu/2wht**
17-grn/2wht**
-18
19-red/2wht
-20
Take care.
Volcom.
Hi Mr. BrotatoChip,
Thanks for your message link.
In order to rebuild the harness from the Secondary O2 sensor (have a new one) to the vehicle harness, (the male plug was riped-off by helliens), assuming they possibly go directly to the ECU, I need to identify the pinout of the ECU 37820-PLA-G01 (KEIHIN CORPORATION), that belongs to the vehicle:
HONDA CIVIC 2001-4DR(ES4)
Version 1.4S
Transmission 5MT
Power 66KW
1396 cubic centimeters
Note: I used the pinning numbers of the receptacles females but in some places, other order is used, maybe of the males? I believe only one is correct.
Furthermore, the marked ones with two asterixes ** : Needs colour name check dued to harness with 21 years of age.
The list with the cable colour is done. It is necessary to identify the Function Names:
For each of the five: Which name of the function? To which position?:
1.Secondary Sensor O2 signal (live) goes to the central wire of a coaxial cable;
2.Secondary Sensor O2 signal (live) ground of the above coaxial cable;
3.Secondary Sensor O2 signal return (different from the ground of the coaxial cable);
4.Secondary Sensor O2 heater line positive;
5.Secondary Sensor O2 heater live negative;
ECU HARNESS LIST 37820-PLA-G01 (HONDA CIVIC 2001)
Connector A (31 pins) Locks up,left side of the male connectors on the ECU:
01-red/2gry (on the Lock side, the right one of the ECU male connector)
02-yel
slot
03-blu
04-wht
05-blk
06-blk
07-yel/2blk
08-yel/2blk
09-blk/2wht
next line
10-yel/2red
11-yel/2gry
12-grn/2red
13-wht/2grn
-14
-15
16-red/2blk
-17
18-wht/2blk
19-blk/2red
20-grn/2wht
21-grn/2yel
next line
-22
23-yel/2gre
24-blu/2red
25-wht/2blu
26-brn
slot
27-grn
-28
slot
29-brn/2yel
30-brn/2yel
-31
Connector B (24 pins)
-1
02-grn (on the Lock side, the right second one of the ECU male connector)
slot
03-brn
04-red
05-blu
06-yel
-7
next line
-8
-9
10-blu/2red
11-wht/2red
-12
-13
14-wht/2blu
-15
16-brn/2wht
next line
-17
-18
-19
20-yel/2blu
-21
slot
-22
-23
24-brn/2yel
DUMMY Connector C (n pins, larger)
DUMMY Connector D (m pins, smaller)
Connector E (31 pins)
01-yel/2blk (on the Lock side, the right one of the ECU male connector)
-2
slot
03-brn/2yel
04-blk/2wht
-5
06-pnk
07-brn/2yel
08-wht/2red
09-grn/2yel
next line
-10
-11
-12
13-red**
-14
15-grn/2blk
-16
-17
-18
-19
-20
-21
next line
22-grn/2brn
-23
24-brn
-25
26-red/2blu**
slot
27-blu
-28
slot
29-yel
30-blu**
31-wht/2blk
(** : Needs colour name check dued to harness with 21 years of age)
Thank you,
Volcom
Version 1.4S
Transmission 5MT
Power 66KW
02-yel
slot
03-blu
04-wht
05-blk
06-blk
07-yel/2blk
08-yel/2blk
09-blk/2wht
next line
10-yel/2red
11-yel/2gry
12-grn/2red
13-wht/2grn
-14
-15
16-red/2blk
-17
18-wht/2blk
19-blk/2red
20-grn/2wht
21-grn/2yel
next line
-22
23-yel/2gre
24-blu/2red
25-wht/2blu
26-brn
slot
27-grn
-28
slot
29-brn/2yel
30-brn/2yel
-31
-1
slot
03-brn
04-red
05-blu
06-yel
-7
next line
-8
-9
10-blu/2red
11-wht/2red
-12
-13
14-wht/2blu
-15
16-brn/2wht
next line
-17
-18
-19
20-yel/2blu
-21
slot
-22
-23
24-brn/2yel
-2
slot
03-brn/2yel
04-blk/2wht
-5
06-pnk
07-brn/2yel
08-wht/2red
09-grn/2yel
next line
-10
-11
-12
13-red**
-14
15-grn/2blk
-16
-17
-18
-19
-20
-21
next line
22-grn/2brn
-23
24-brn
-25
26-red/2blu**
slot
27-blu
-28
slot
29-yel
30-blu**
31-wht/2blk
Thank you,
Volcom
Hi Mr. BrotatoChip,
I found some more information and I compiled a corrected list.
I believe there is no colour mistakes and I put the numbering sequence like in the manual.
I'm on reading some more information to find the return cables exactly and looking for a more complete version of the manual.
The Chassis and Engine codes of the models are pretty much mixed in a way that looks more a puzzle than I would say a Good American Manual, with all the information, it normally brings.
Who gives what he/she can's to no more is not obliged.
Take it easy.
Furthermore There are more tides than sailors, if you know what I mean.
Merry Christmas.
Best Regards.
1.CONNECTOR A
PO2SHTC BLK-WHT 1
IGP2 YEL-BLK 2
IGP1 YEL-BLK 3
PG2 BLK 4
PG1 BLK 5
PHO2S WHT 6
CKP BLU 7
VCCR YEL 8
KS RED-BLU 9
SG2 GRN-YEL 10
SG1 GRN-WHT 11
IACV BLK-RED 12
EGRP WHT-BLK 13
14 NC
TPS RED-BLK 15
16 NC
17 NC
VSS WHT-GRN 18
MAP GRN-RED 19
VCC2 YEL-BLU 20
VCC1 YEL-RED 21
22 NC
LG2 BRN-YEL 23
LG1 BRN-YEL 24
25 NC
TDC GRN 26
IGPLS4 BRN 27
IGPLS3 WHT-BLU 28
IGPLS2 BLU-RED 29
IGPLS1 YEL-GRN 30
31 NC
2.CONNECTOR B
1 NC
INJ4 YEL 2
INJ3 BLU 3
INJ2 RED 4
INJ1 BRN 5
FANC GRN 6
7 NC
ECT RED-WHT 8
9 NC
ALTL WHT-BLU 10
11 NC
12 NC
ALTF WHT-RED 13
EGR BLU-RED 14
15 NC
16 NC
17 NC
18 NC
19 NC
20 NC
PCS YEL-BLU 21
22 NC
23 NC
24 NC
3.CONNECTOR E
IMO FPR GRN-YEL 1
SHO2S WHT-RED 2
LG3 BRN-YEL 3
SG3 PNK 4
5 NC
SO2SHTC BLK-WHT 6
MRLY RED-YEL 7
8 NC
IG1 YEL-BLK 9
10 NC
11 NC
12 NC
13 NC
14 NC
15 NC
EPSLD LT GRN-BLK 16
17 NC
ACC RED 18
19 NC
20 NC
21 NC
BKSW WHT-BLK 22
K-LINE LT BLU 23
SEFMJ YEL 24
25 NC
NEP BLU 26
IMOCD RED-BLU 27
28 NC
SCS BRN 29
30 NC
MIL GRN-ORN 31
Take it easy.
Merry Christmas.
Best Regards.
1.CONNECTOR A
PO2SHTC BLK-WHT 1
IGP2 YEL-BLK 2
IGP1 YEL-BLK 3
PG2 BLK 4
PG1 BLK 5
PHO2S WHT 6
CKP BLU 7
VCCR YEL 8
KS RED-BLU 9
SG2 GRN-YEL 10
SG1 GRN-WHT 11
IACV BLK-RED 12
EGRP WHT-BLK 13
14 NC
TPS RED-BLK 15
16 NC
17 NC
VSS WHT-GRN 18
MAP GRN-RED 19
VCC2 YEL-BLU 20
VCC1 YEL-RED 21
22 NC
LG2 BRN-YEL 23
LG1 BRN-YEL 24
25 NC
TDC GRN 26
IGPLS4 BRN 27
IGPLS3 WHT-BLU 28
IGPLS2 BLU-RED 29
IGPLS1 YEL-GRN 30
31 NC
2.CONNECTOR B
1 NC
INJ4 YEL 2
INJ3 BLU 3
INJ2 RED 4
INJ1 BRN 5
FANC GRN 6
7 NC
ECT RED-WHT 8
9 NC
ALTL WHT-BLU 10
11 NC
12 NC
ALTF WHT-RED 13
EGR BLU-RED 14
15 NC
16 NC
17 NC
18 NC
19 NC
20 NC
PCS YEL-BLU 21
22 NC
23 NC
24 NC
3.CONNECTOR E
IMO FPR GRN-YEL 1
SHO2S WHT-RED 2
LG3 BRN-YEL 3
SG3 PNK 4
5 NC
SO2SHTC BLK-WHT 6
MRLY RED-YEL 7
8 NC
IG1 YEL-BLK 9
10 NC
11 NC
12 NC
13 NC
14 NC
15 NC
EPSLD LT GRN-BLK 16
17 NC
ACC RED 18
19 NC
20 NC
21 NC
BKSW WHT-BLK 22
K-LINE LT BLU 23
SEFMJ YEL 24
25 NC
NEP BLU 26
IMOCD RED-BLU 27
28 NC
SCS BRN 29
30 NC
MIL GRN-ORN 31
jameStype
Jul 1, 2006 10:01 AM
