5psi?
Old Oct 19, 2006
  #31
andyman97's Avatar
Turbo Guru
obdI and II maps are supposed to be 1.8 bar.
Old Oct 19, 2006
  #32
familycar's Avatar
that is becasue there is a positive pressure in the manifold when under throttle. the more throttle you give the more pressure is present. so the map has to be able to read pressure. but it shouldnt be able to adjust for pressure above what the motor draws. if you running we will say a 1/2 bar of boost this is still above what the map should be able to read. with the 2 bar(1.8 bar) sensor it reads 1 bar vaccum and 1(.8) bar pressure which is what the motor creates n/a. i think it may be able to recognize boost at part throttle but at WOT you should go pretty damn lean being that there is more than .8 bar present in the manifold. make sense?
cukaracha
Jul 23, 2015 08:50 AM
Maple50175
Engine Swaps
Apr 21, 2011 10:28 PM
karizzle
Engine Swaps
24
Jan 15, 2007 08:44 AM
JetBlu01
Jun 14, 2004 03:01 PM
Boosted2k2
Feb 18, 2004 01:05 AM
