Emanage help....again
Old May 27, 2005
andyman97's Avatar
Turbo Guru
Ok, so I had wired in the emanage yesterday. Ran fine once I got it straight. This morning, after driving about 30 miles or so, I threw a code. No biggie, I figured it was a wire or something. Took it to autozone for a read and it gave a P0107 for MAP/Barometric pressure input lower than expected. So I figured maybe I didn't have a strong enough connection.
So I went out and re-connected the green wire to the map wire into the ecu and the white wire going out to the sensor. Cranked it and no CEL. Then after about 30 seconds, it started flashing a CEL at me. So I figured I would just bypass the emanage to see if it was the problem. I connected the map wires back together and disconnected the emanage map wires. It's still flashing a CEL after running for 30 seconds.
Now I haven't tried to pull the flashing code but I'm pretty sure it's still something with the map. No idea what to do from here. Any help would be appreciated.
Old May 27, 2005
andyman97's Avatar
Turbo Guru
Well, seems that my map sensor itself is bad. Replaced it and no cel....I'll see what happens next.
Old May 27, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I know if you try to correct for huge injectors on our cars it will trip a map cel. Maybe it is just the sensor, wierd that it would crap out just then though, huh. Go figure
Old May 27, 2005
andyman97's Avatar
Turbo Guru
Well, I decided to do everything one piece at a time instead of trying to throw it all together at once so I'm running the emanage zeroed out on a stock setup. I figured out why the map was bad. Last night when I installed the emanage, I didn't have a strong connection with the map wire to the emanage input. So I tried reversing the wires to see if that fixed it and I think it may've scrambled the sensor.
dezod
Engine Management
112
Feb 7, 2008 12:38 PM
MadWheel
Bolt-on Engine Performance
May 15, 2004 09:55 AM
chesireCAT
Engine Swaps
Mar 2, 2004 07:29 PM
Ahtasham
Engine Swaps
Mar 2, 2004 11:01 AM
