missing link problem
Old Jan 13, 2005
CrewChief's Avatar
Remebers the old days
CrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of lightCrewChief is a glorious beacon of light
What is the deal with the hole on the side of the missing link. I got the synaps one used and when I installed it the car ran like crap. I would cover the hole on the side and it would run fine. whats up with that.
Old Jan 13, 2005
Pb4uGo's Avatar
Pb4uGo is an unknown quantity at this point
Are you sure your ML isn't installed upside-down?
Old Jan 14, 2005
CrewChief's Avatar
it can only go in one way. and the hole is between the inner check valve and the map sensor on the side of the link
Old Jan 14, 2005
StreetLevelPerformance's Avatar
Your Parts Guy
StreetLevelPerformance is on a distinguished road
You need to put the filter in there. Im guessing you didnt get one because you got it used?
Old Jan 14, 2005
BIG's Avatar
BIG
where would he get a filter then>> :|
Old Jan 14, 2005
CrewChief's Avatar
I got the filter but didn't know what it was for. what is it for?
Old Jan 14, 2005
Your Parts Guy
Cut a piece off of it and stuff it in the side. You will notice after a while of using it that it turns black. That's when you replace the filter with another piece.
Old Jan 14, 2005
CrewChief's Avatar
so you have to keep doing this over and over? and when you run out then what. May be i'll just keep the little black box that came with the tsi kit. I just heard that with the missing link you got better boost transition
Old Jan 14, 2005
JetBlu01's Avatar
New Member
JetBlu01 is an unknown quantity at this point
what do u do when u run out b/c I'm running out....hey steve, i did the same thing when I first put my in...I was like WTF then I looked in the package and figured it out like 30 minutes later
Old Jan 14, 2005
CrewChief's Avatar
the filter looks like the same stuff earplugs are made out of. maybe you could use that.
Old Jan 14, 2005
civic01vtec's Avatar
when you run out...........use a sponge or a piece of foam........or simply clean a old one.
Old Jan 14, 2005
CrewChief's Avatar
again why is it there?
Old Jan 14, 2005
thebigjap's Avatar
thebigjap is an unknown quantity at this point
I guess that mechanically the "missing link" takes in air to smooth out the transition from vacuum to boost, though, I'm not entirely sure of what happens to that air. The hole is the passageway for that air and the filter keeps the dirt out. That's my guess...a theory, of sorts...
Old Jan 14, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
what kind of sponge would you be suggesting?
Old Jan 14, 2005
Titleist71's Avatar
I zip tied a piece of upholstry foam around it and when it's dirty I wash it or just turn it a little to a cleaner part.
Rogelio Rey
May 24, 2015 08:30 PM
pratik05
May 15, 2015 01:54 PM
shindrome
Exterior
May 5, 2015 02:50 PM
cooldan1
Apr 23, 2015 10:49 AM
usajags84
Apr 10, 2015 09:54 PM
