EternalBlue_Vic BOV Clip
Old Dec 30, 2004
  #31
AceAltima's Avatar
AceAltima is an unknown quantity at this point
Well a combination...I think it's mainly due to the fact that in the vid he's a very low psi, so the boost vacuum transition isn't the best, hence causing the valve to not work correctly...
Old Dec 30, 2004
  #32
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
/\/\Should i adjust the spring on the BOV?? Tighten or loosen?
Old Dec 30, 2004
  #33
AceAltima's Avatar
It' say loosen it up a lil bit...but if you're only at 1psi then it isn't worth it to loosen
Old Dec 30, 2004
  #34
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
Good info AceAltima
Old Dec 31, 2004
  #35
Boosting Daily
i think it's turkeying out at full boost too, cuz whenever i shift, the turbo should stay spooled but when i shift, it drops down to 4psi then spools back to 6lbs. Okay, i'ma tighten it a bit and get back to ya'll later. Thanx Ace
Old Dec 31, 2004
  #36
AceAltima's Avatar
A turbo will loose spool when you shift gears...just a lil...tha sounds normal???
Ensure you have no vacuum leaks, and where do you have your BOV's vacuum source from??
Lastly, do other memembers using the same valve have similar problems or no???
Old Dec 31, 2004
  #37
TheSmuggler's Avatar
^^Uh oh us autos dont loose boot lol
Old Dec 31, 2004
  #38
Boosting Daily
i have no vaccum leaks, spend a good while checking it out. Idle is smooth, so no leaks that i can find. My vaccum source comes from here: The kit comes with a computer module that you need a vaccum source for. So i T'ed off the vaccum hose to the right of the throttle body and T'ed the line off the throttle vaccum to the BOV. The vaccum should be pretty strong. My pillar boost gauge is T'ed off that line too.
Old Jan 1, 2005
  #39
AceAltima's Avatar
Try to elimate so many "T" in your line
Again, I'm not sure at all since I have a Nissan, but don't you have any sources of direct vacuum from your intake manifold???
See my setup is this way
Wastegate Side Nipple is sourced from the compressor housing
Wastegate Top Nipple goes to the Profec Stepper Box
Other side of of the Profec is sourced from the charge pipe before the TB
Boost gauge come from a direct source of vacuum that used to goto the EGR gabarge
BOV is from the FPR line (again, direct from the intake)
In all reality, i'd like to tap my brake booster line for the blow off valve, and elimate the T in my FPR...but even if that T for the FPR has a leak, it will only make the car run rich (vacuum leak at the FPR simulated WOT)
Old Jan 1, 2005
  #40
baggedblue02's Avatar
baggedblue02 will become famous soon enoughbaggedblue02 will become famous soon enough
YEAH!!!!!
I got to see my cd player one last time
Sounds real good btw. Glad to see it all done
Old Feb 8, 2005
  #41
2K1Civic17"Gabe's Avatar
wish the vid's worked. I want to hear what its gonna sound like.
Old Feb 8, 2005
  #42
Boosting Daily
/\/\/\ Hehe, sorry dude. Hit either me or KalliGarri up on AIM and we'll get ya the file.
Old Feb 9, 2005
  #43
I **** on AIM, hehe. I hate everything AOL associated. Its all good, I can wait a couple weeks. I watched your 0-100 or something run a few times with the volume up, so I heard it. Thanks though.
Peace
Old Oct 4, 2005
  #44
Boosting Daily
Yo! Anyone have the "Inside" video still?? I accidenally deleted it off my computer. If someone has it PLZ let me know!
nirvanaguy
25
Oct 26, 2017 07:26 PM
charmon4815
General
Sep 22, 2015 08:00 AM
emiixo
Exterior
Sep 22, 2015 03:53 AM
hondalx2002
18
Sep 15, 2015 10:54 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
