EternalBlue_Vic BOV Clip
Old Dec 28, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
Just thought id help him out with this
He has the TSI Extreme Turbo Kit, and all the kits come with the SAME BOV
Inside Clip
Outside clip
Old Dec 28, 2004
TheSmuggler's Avatar
w0000000000000000000000t that almost convinced me to buy Dezonds kit for my car instead of saving up for a an rsx type-s
Old Dec 28, 2004
abmerop18's Avatar
Jam out with your clam out.
doesnt work for me
can you make it a .mov or .avi file?
Old Dec 28, 2004
KalliGarri's Avatar
sorry dunt know how
Old Dec 28, 2004
civic01vtec's Avatar
sounds nice........from inside the car, it sounds like a little bit of compressor surge.
Old Dec 28, 2004
ImportRacer2123's Avatar
K20 Member
Why not just do a k20 swap into the civic?
Old Dec 28, 2004
Because the RSX is a nicer car...
Old Dec 28, 2004
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
sounds nice, you should make a vid of the speed. from a launch to 1st, 2nd, and 3rd. =) it could be my christmas present!!!
Old Dec 28, 2004
C2i0v0i1C's Avatar
SuperMODrizd
car is too quiet in general
Old Dec 28, 2004
AzNmiKex215's Avatar
2k1civic.com O. G.
sweeeetness
Old Dec 28, 2004
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
[QUOTE=KalliGarri]Just thought id help him out with this
Hey dude!! Thanx for hosting them!!
Old Dec 28, 2004
Boosting Daily
Na, that was just from when it was running shitty (way too lean) Both of the clips i'm running only at 1/5 throttle. Just enough to spool the turbo and get the BOV working.
Old Dec 28, 2004
Boosting Daily
Na, i like the way my car sounds. I'm runnin a Tanabe Super Racing Medallion, but the turbo quiets it up ALOT. I love the sound of a high pitched compressor screaming past you rather than the rumble of an exhaust.
Old Dec 29, 2004
allmotor's Avatar
nor cal 7thgens
sounds nice
Old Dec 29, 2004
KalliGarri's Avatar
Wait so ur turbo made ur exhaust more quiet?
Old Dec 29, 2004
Boosting Daily
/\/\Yes, because the exhaust flow is less direct. Instead of just passing through the header and down the exhaust in a straight through design. The exhaust flows around an exhaust turbine and (at times under max boost) through a tiny wastegate, the exhaust flow is less direct, thus quieter.
Old Dec 29, 2004
exturbo6's Avatar
i have the same kit just t28bb upgrade and my car sounds alot louder then that..inside and out.
Old Dec 29, 2004
Boosting Daily
/\/\mine's ALOT louder than that. Like i said that was only 1/5 throttle and only about 2psi max.
Old Dec 29, 2004
Boosting Daily
I've worked out most of my fuel cut problems and have the ICU tuned to where i'm running pretty good now. (Just a little rich, but still better than lean) As soon as i get a chance i'll get some vids of me on it WOT. At WOT traction is tough though
Old Dec 29, 2004
exturbo6's Avatar
i c. well good to hear your fixin it up..im running rich..6psi..not bad at all...just waiting to get a new fuel system not a fan of the one it comes with.
Old Dec 29, 2004
Boosting Daily
/\/\ True, but it gets we where i need to go and rapping whoever's beside me.
Old Dec 29, 2004
AceAltima's Avatar
AceAltima is an unknown quantity at this point
Soooooooounds good....I wish I could get a clip of my type s for you boys :]
And the car sounds good too...I agree on turbo noise>ehxuast noise...then again I do run an open dump, so when i'm on it it's all kinda noise goin on!
The valve does sound very similar to the Turbo XS Type H-34 and the RFL...not bad...very agressive
Old Dec 29, 2004
Boosting Daily
Heck yeah! Greddy type S is like PSSSSHHHHHHH *Jizzzz*.....oops
Open Dump? Meaning an external wastegate not routed back to the exhaust?
Old Dec 29, 2004
AceAltima's Avatar
Thats right...there isn't really room to correctly re route the wastegate...
Old Dec 29, 2004
Boosting Daily
On our project 240-> silvia conversion with a T304s, we routed the piping from the wastegate to exit on a aluminum port we fabbed up on the driverside fender. We're expecting flames!! haha
Old Dec 29, 2004
AceAltima's Avatar
it'll be loud!
expect it to scare small kids and unassuming drivers!!
Old Dec 29, 2004
someguy's Avatar
someguy is an unknown quantity at this point
hey you got a slight turkey sound(you can hear it outside). my friends MSP does the same thing(cause of his intake)
Old Dec 30, 2004
Boosting Daily
/\/\is that a bad thing?
Old Dec 30, 2004
AceAltima's Avatar
Thats slight compressor surge...usually do to your BOV not working at maximum effeciency...like you're not at a high boost or your vacuum source is weak, or your valve is setup for to high of a PSI
Turkey sounds are not good...many Mazdaspeed Protege 5 owners are having similar problems when changing valves and the such...
I wouldn't worry to much about it at low boost, but if you really romp into it and boost a lil (like 5-8psi, low boost) and you still get surge...thats not good
Basically surge is the compressed air filling up your charge pipe, as your Throt Body is closed, and it's making your compressor spin backwards...hence making that noise come out your intake
Old Dec 30, 2004
KalliGarri's Avatar
so is it that the BOV is too stong, not letting air out, or too week, letting too much out?
