3 inch piping
Old Dec 29, 2003
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
3 inch piping
I was wonderign if i was to get 3 inch piping for a turbo, would there be a ny loss of power at lower revs, cuz of the lack of backpressure, cuz I wanna get a HKS Carbon-Ti muffler a,d custom piping (maybe titanium) and wanted to know if it would be beneficial or not...
thanks...
Old Dec 29, 2003
Jaykuai's Avatar
ish...
i thought that with turbo you dont have to worry about back pressure..
Old Dec 29, 2003
alluneedis1mlke's Avatar
alluneedis1mlke is an unknown quantity at this point
3 inch piping is wayyyy to big, only expect one thing if ya get 3inch piping...thats power "LOSS" you might not get backpressure but youd be flowing wayyy to much air through your pipes....
Old Dec 29, 2003
What motor are you turboeing? also what size turbo? specs please...turbine and compressor side if ya have those numbers...etc these are all factors but most likely if your running t3 or smaller like most civics should if their not built then specs should be around .48/.42 or around there...ummm 3 is still to big, your turbo will not lag but at same time you wont get any extra power from just bigger piping ...good luck doe
Old Dec 29, 2003
Anotherslo1's Avatar
Anotherslo1 is an unknown quantity at this point
^^^^^ Yup, depends on how your turbo is built and what type of engine/mods you have. I am using a 3" piping for mine.
Old Dec 29, 2003
well im stating of with the SF kit maybe, with the upgrades turbo, alck injection and equal leght mani,
waht piping would be beter 2.5 or 2.75 ?
Old Dec 29, 2003
IS it gonna be a stock SF turbo, or is Stafford gonna custom build the internals of your turbo? Anyways, I would go 2.75 personally. But, you definetly want a minimum of 2.5 for the turbo system.
Old Dec 29, 2003
Green Civic's Avatar
2.5 is usually a good size piping for normal turbo use. 3" piping is really used for 20+ psi on highly modded cars. You can use a 3" pipe, but you wont see any big power untill you get enough boost moving the exhaust gasses fast enough.
Old Dec 29, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
um, you don't want backpressure period ... na or turbo
Old Dec 29, 2003
andyman97's Avatar
Turbo Guru
Holy misinformation, batman.
Once I get my build done, I'm going to upgrad to a 3" dp and full 3" with no muffler all the way back.
On a d17, if it's stock, it runs off of backpressure. Upgrading to a 2.5" will loose power with that setup for sure. I know mine does.
For a turbo setup, if you're running 8+ daily, I'd say a 3" would be a good choice for it.
Old Dec 29, 2003
anyone know what piping does a Tanabe Racing Medallion have??
Old Dec 29, 2003
I believe 2.5 I thats what I have on my tanabe i 4get doe
Old Dec 29, 2003
Catalyst's Avatar
Catalyst is just really niceCatalyst is just really niceCatalyst is just really niceCatalyst is just really nice
the bigger the pipe the better. With a turbo you do not have to worry about loss in back pressure. I am proving that right now. My car has the 3" downpipe and no exhaust. All i have is the downpipe. Did i lose power? No. Did i gain power? Yes.
Funny how that works.
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
Islesfan
Sep 29, 2015 03:42 AM
