My few interior mods.
Old Nov 17, 2007
AmbulanceMonkee's Avatar
A couple new shots of my interior. In the past month, I've swapped to an 05 EX cluster, managed to fubar the install so my hi beam indicator didn't work, and the abs light was on, in my car doesn't have abs. Got both of those issues fixed and managed to trip my abs light by turning on the ignition with the cluster unplugged, to diagnose the hi beam issue. Got the indicator working, and took the cluster apart to put tape over the abs indicator. I would have been concerned about fixing it right, if my car had abs. In the process, reversed my gas gauge, so when you shut the car off, it went right to full. Fixed that, and reset my abs light with the DIY on the first shot. Also hardwired my radar detector, and stuck it above the mirror. Two switches seen are for fogs (didn't like the ebay switch/harness, so i made my own) and for 3 extra outlets for my GPS laptop power supply and fm transmitter. Shift **** is ebay, and may get replaced eventually, and the silver trim on the dash is Honda OEM. Also removed aftermarket tach, since i swapped to cluster with one. Other than needing a good vacuuming/shampooing, what do you guys think of my interior??
Old Nov 17, 2007
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
Re: My few interior mods.
i have the same switch for my fogs, but y 2?
Old Nov 17, 2007
TRIZ's Avatar
Looks pretty good. Same cluster, same fog light switches.
IMO, the dash kit and the **** dont match.. if it was swapped out for a sliver **** like the type r ****, it'd flow a lot better. Its just a little distracting.
Other then that, looks like a cool civic.
Old Nov 17, 2007
lordhelmet's Avatar
I dont like the **** at all. The rest looks great.
Old Nov 17, 2007
actually tried a silver one, and it didn't match the factory silver trim/dash kit, so i gave up and used a black one, to match all the black in the interior. i kinda see your point, but black is the better of the two options. here's a pic of the old ****. nevermind the position of the old tach, it was there so i didn't end up with visible holes when i removed it, as it was only temporary till i got around to swapping clusters.
the second one is for the extra outlets, for laptop, etc. i ran power from the under hood fuse box, fused it inline, goes through the switch, to outlets. That way i can have power with the car off to shut down the laptopt if the battery's dead, etc. outlets may eventually be removed, and switch will be used to control cold cathode lights under dash, etc., as the dx has only a one bulb dome light for interior light.
Old Nov 17, 2007
TRIZ's Avatar
custom shift ****!!
Old Nov 17, 2007
yeah, sure, when i finish cleaning up after my roommate, working 60 hours in 5 days this coming week, fixing a couple of my friends' and my sister's computers, swapping my desktop's video card and power supply to my server, and installing a new one of each in my main computer, re-bolting-on the OEM exhaust tip i ripped off on a curb the other night, changing over to my winter wheels, and checking all the bolts on my suspension, i'll see if i can find time to sand down the old **** and match the color up to the dash trim.
Old Nov 17, 2007
EG06KRS's Avatar
EG06KRS is an unknown quantity at this point
Dude I think it looks really nice. Great job!
Old Nov 17, 2007
01HonderCivic's Avatar
Don't be a n00b, search ftw
My Ep3 **** looks pretty good with my dash kit...
Your interior looks good either way though
Old Nov 17, 2007
thanks. i'll look into the ep3 ****, then. if the price is right, i may pick one up
Old Nov 17, 2007
HonCiv02's Avatar
HonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond reputeHonCiv02 has a reputation beyond repute
interior looks good, i like the cluster swap.
Old Nov 17, 2007
sl33pyriceboi's Avatar
invest in a revo. it'll be worth it.
Old Nov 17, 2007
thanks, rep returned
thinking about it. how difficult to install??
Old Nov 17, 2007
Pretty much remove center console, unbolt the linkage, unbolt the shifter assembly, and redo for the revo. I'd rate it as faily simple...
Old Nov 17, 2007
gsniper666's Avatar
gsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura aboutgsniper666 has a spectacular aura about
haha.. looks good man... keepin it clean is allways the best ay to go.. congrats
Old Nov 18, 2007
speedfoos's Avatar
Looks really good man. I'll echo on the Revo. I even wrote a DIY on it here. I think you should follow mine because it's better than the other ones. It amazes me how tall your shifter looks compare to a Revo. I'd recommend the RSX stock **** over the EP3. It will match your interior better than the EP3. Unless I'm talking out my *** and the EP3 is silver too!
Here's the Revo and RSX **** in my car.
Old Nov 18, 2007
cyberphox's Avatar
cyberphox is an unknown quantity at this point
i have those same switches..and believe it or not..i'm just curious how you drilled a hole in those slots and still got the buttons to stick in?
Old Nov 18, 2007
icuslipn2's Avatar
icuslipn2 is an unknown quantity at this point
did u install your fog lights yourself, if so could u email me how to instructions i just ordered my fog lights email is icuslipn2@aol.com
Old Nov 18, 2007
handaaccessories.com has info
Old Nov 19, 2007
That looks really good. I'll keep that in mind. Will prolly be my first mod in the spring. Right now, it's in the 30's here, and getting too cold to be out working on my car.
I took the blank out, drilled a hole in it big enough to fit the round part on the back of the switch with the contacts through, and then glued the back of the switch to front of the blank to hold it in there. no problem so far.
it's a bit in depth. i'd have to write a diy, and that's been done already, i think. check around the site, or like gearbox says, h and a has a pdf of the install instructions for dealers. should be about the same even if you get the ebay kit.
Old Nov 20, 2007
jamis33's Avatar
You Stay Classy, San Diego
did u paint ur interior urself?? and factory head unit cmon. All a factory head unit is good for is a paperweight LOL i'd definantly reccomend gettin a different one.
Old Nov 21, 2007
Read the thread, dude. It's not painted, it's the OEM dash trim kit. As far as the head unit, quarters for my job is not in the nicest neighborhood. My last car got broken into and they took a pry bar to the deck. The sound from the stock stereo isn't as bad as some other cars, and leaving the audio stock minimizes the chances of someone smashing out my windows. I'm gonna get some wheel locks, and call it a day. Thieves here aren't into stealing exhausts, etc. They just smash windows and grab anything that looks expensive. I don't keep anything inside my car.
Old Nov 21, 2007
jamis33's Avatar
good idea i live in a small town so its not too bad but i still wanna get a good alarm just to be safe. I like the alpine head units that flip around wen u turn the car off those are sweet
Old Nov 21, 2007
pinoyboy_drew's Avatar
pinoyboy_drew is an unknown quantity at this point
damn man looks like u did alot of work on it........completely worth it......its good!!!!
SammySC
121
Apr 7, 2017 07:43 PM
cferry7
Oct 18, 2015 06:32 PM
dhuff
Sep 28, 2015 08:35 PM
Dsmak
Sep 22, 2015 05:16 PM
kevfarr
Sep 18, 2015 02:28 PM
