ticking noise when i turn
Old Mar 12, 2003
hypnotic7thgen's Avatar
hypnotic7thgen is an unknown quantity at this point
About a month ago I spent some well earned money on a set of Eibach Sportline springs that dropped the car maybe 2.5". Well just the other day I was making a right turn and I heard a sort of ticking noise. Nothing seems to be visibly wrong, but I was just wondering if anyone else has noticed this same problem. Any information is greatly appreciated.[IMG]i/expressions/face-icon-small-confused.gif[/IMG][IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 12, 2003
Sim012's Avatar
Sim012 is an unknown quantity at this point
Sportline drop your car only about 1.4 inches. But anywayz, my friend installed some lowering springs the other and it had the same ticking noice when he turns.
Old Mar 13, 2003
sorry I ment 1.5" , I just don't kno what the deal is I hope its nothing major.
Old Mar 13, 2003
MattC1's Avatar
MattC1 is an unknown quantity at this point
I hear it too[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Mar 13, 2003
DizWikedCivic's Avatar
i have skunk2 coilover i had it lower about 2 3/4" in the front and i these clankin noise becuase when i turn the wheel the spring would move around too, but the other day i raise up my car and now i dont hear any more noise, so im guessing since my car is higher the spring are more compress and the spring wont move after i turn
Old Mar 13, 2003
andyman97's Avatar
Turbo Guru
Ok, if you did your own spring install you should remember that there was a rubber piece that sits right on top of the spring. This piece is bigger on one side and smaller on the other. The smaller side needs to be seated on the spring. The reason your hear this noise is because when you turn, the spring turns also because it isn't secured correctly. Take the strut out and check to make sure it's seated right. This should solve your problems [IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Mar 13, 2003
Are you talkin about the bumpstop?? If that doesn't work should I be worried about perminant damage
Old Mar 13, 2003
andyman97's Avatar
Turbo Guru
No, it's not the bumpstop. It's the gasket/bushing that sits on TOP of the spring itself. Try adjusting it. Shouldn't have any damage from that. Something else it may be is the dustboot on the front, it may be rubbing on the strut shaft.
Old Mar 14, 2003
ok, thank you for the help much appreciated
Old Mar 17, 2003
noahnoah's Avatar
noahnoah is an unknown quantity at this point
does that advice go for the neuspeed sport springs also? I have the same noise. At first all it was was ticking when I turned, but I ran over a pretty nice bump in the road and now I hear something that sounds like something is loose? When I'm driving just straight I hear something jiggling or shaking? Any help here?
Old Mar 18, 2003
DragonAce's Avatar
DragonAce is an unknown quantity at this point
i have it on my Eibachs, so ya, i'd say that any after market spring could potentially have this problem..
i did have a look tho and all seemed well, so i took it to Honda for a TD..
the guy said they'd try replacing my LF strut (under warranty of course ) ..
tho he said they've had other cars in with the same problems..
one of them ended up being a problem with some metal seperating partially (bad zaps i guess (welds)) and tight/hard rights would make it click also..
Old Mar 18, 2003
PunkingCivic's Avatar
I need TP for my bunghole
I have just lowered my car on 3/16 with the Neuspeed Sport springs at first I heard a creeking noise when I would steer for the first two days, so far in the morning. But from what I notice where the springs a coiled more tightly wound and will touch once the car is seated on the ground could cause the creeking noise. The reason being is becasue the strut and spring are also apart of the cars steering.
Also, If anyone else has these springs are you experiencing bouncy ride?
Also where the pring are more tighly wound are the the top three coils really close, almost touching?
Well please advise and chat at you people later.
Supramk3
May 11, 2015 07:55 PM
civicns
May 8, 2015 09:49 PM
edgenet
May 2, 2015 08:00 PM
SSMatey
Apr 13, 2015 06:09 PM
opticalvetc
Jan 1, 2002 08:32 PM
