Newbie Needs Suspension Help =)
Old Jan 9, 2003
DrunkrnCivic's Avatar
DrunkrnCivic is an unknown quantity at this point
hi i was wondering what company makes the best coil over springs to buy with only $200 and where i could get some besides online? thx ^^
Old Jan 9, 2003
VNlilMAN's Avatar
The Standard One
only sleeved coilovers i recommend are ground control or skunk2, both are around the $300 range. another ok one is the VIS v-spec coilovers which are a lil more then $200. but ya if you want to stay under $200 i would recommend sticking to springs... remember theres things such as shocks and camber kit to worry about. you have a greater chance of blowing your shocks with sleeved coilovers then springs cause of the spring rates. also installation runs around $70-$100, unless if you DIY that is..
btw, check out the socal section. add yourself to the member list. we just had a huge meet around irvine.... there was a meet in diamond bar which had around 50 7thgens.. not sure when the next big one will be so ya just keep checking there... there are always small meets here n there, i know there are a few members from around your area
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
pilebuck13
Sep 21, 2015 10:45 PM
czarlun
Sep 14, 2015 08:16 PM
