Air Conditioning Post issues about air conditioning here
AC Blowing cool - but not cold
Old Sep 14, 2015
Deebo12's Avatar
Deebo12 is an unknown quantity at this point
Anyone that can help out with this, I would really appreciate it. Several months ago my AC started blowing warm air. Checked the engine and saw that the compressor clutch was not spinning. Replaced the relay and clutch engaged, and started blowing cold air. A few weeks after, the fans stayed engaged for hours after the car was off. Again, replaced a relay and solved the issue. Now the air is blowing cool, but not cold. Had the system evacuated, vacuumed, pressures on high and low side holding steady at proper pressures. Still not blowing COLD air.
Last night the temps here crept down into the 50s and I had the vent open (AC not on and no recirculate) and noticed that the air coming through was not as cold as it should be. This makes me wonder if the actual temp control inside the car is not working. My question are: Is there a way to check this (if so how) and does anyone have any experience with a similar issue that could offer some advice?
Apologies if I am making mistakes in how to post...newbie here.
Old Sep 17, 2015
corysam's Avatar
corysam is an unknown quantity at this point
Re: AC Blowing cool - but not cold
Maybe check the blend door and the blend door actuator. If these cars have such a thing. I'm new to the Civic and new cars in general.
Old Sep 26, 2015
06 EX Mild Mods's Avatar
06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about06 EX Mild Mods has a spectacular aura about
What corysam states sounds reasonable this is likely an electronically controlled butterfly valve that routes the air across or around the heat core. Was the Freon charge weight measured in, the weight of the amount of Freon is how the correct amount of charge is determined. I've worked on everything that has a motor for around 40 years, but the resident expert is Ezone who is a long time Honda Mechanic. I'd contact him.
Old Sep 26, 2015
Locate the HVAC blend (temperature) door actuator and linkages, push/pull give it a little assistance moving back and forth, and see if it's just a sticky door that isn't moving all the way to the cold position.
I've seen this help on a couple higher mileage cars, but nobody has wanted us to tear the dash out to see if there's a problem inside the HVAC housing.
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
Civic65
Jul 19, 2015 10:13 AM
Jul 14, 2015 03:39 PM
