Suspension questions
Old Dec 18, 2013
cd2781's Avatar
cd2781 is an unknown quantity at this point
Ok I want to upgrade my suspension but I don't really wanna go lower than stock. What are my options? Thanks in advance
Old Dec 18, 2013
GolNat's Avatar
Prelude Owner
Re: Suspension questions
Tokico Blues on stock springs. Eibach Pro Kit for a small drop.
Old Dec 18, 2013
Kennykid2002's Avatar
Kenny the Ricer
Define "Upgrade"
Do you want it to perform better?
Aftermarket Coilover systems will give you the best fitment, as you can control the height of the car to your exact satisfaction.
Old Dec 18, 2013
cd2781's Avatar
yes i want it to perform better. i was thinking about the eibach pro plus kit with the sway bars cuz it only drops it like 1". I have rough roads and lots of speedbumps where i live. With just a 1" drop, is it really necessary to upgrade the shocks?
Old Dec 19, 2013
GolNat's Avatar
Prelude Owner
It's necessary to replace the shocks in order to get the best upgrade in performance. Only replacing the springs will still give you an upgrade in handling just not as good as with performance shocks to match. Just upgrading to new performance struts will make it perform better.
The Eibach sway bar kit is not the best. A Progress rear sway bar would be a better option as to is larger then the Eibach one. Also an upgraded front bar may not be needed. I just upgraded my rear and was happy with how much more neutral the car handled, so I left the from bar alone.
Replacing worn suspension components will help also like sway bar end links, ball joints, LCA bushings and sway bar bushings.
Old Dec 24, 2013
cd2781's Avatar
Ok i found the tokiko blues i think. They call them hp's? I hope you can see the attached picture and tell me if these are the right ones. Also with the eibach sport kit, will i need a camber kit to get a proper alignment done?
Old Dec 25, 2013
GolNat's Avatar
Prelude Owner
Yea that's them.
With a pro kit you should be ok without a camber kit. Only benefit would be the ability to tune your suspension using camber.
Old Dec 25, 2013
the sport will go lower, potentially you need the rear ones to bring the camber back to where it should be, closer to zero.
could be later, after you check if you are understeering too much, such as a rainy day. downside is you will need to align car again.
Old Dec 25, 2013
GolNat's Avatar
Prelude Owner
^ I fail! Good catch.
I had a Sportline kit and needed a rear camber kit to get back into spec (this is what the alignment shop told me). If you don't mind riding out of spec alignment then you will be ok.
Old Dec 25, 2013
clinton_hedrick's Avatar
clinton_hedrick is an unknown quantity at this point
You could always go with an RSX-S rear sway bar instead of buying an aftermarket one. You can also swap the springs from an RSX to get a similar ride height with a firmer ride.
Old Dec 27, 2013
^ will be slightly higher, since the RSX is heavier
EdGasket
40
Nov 27, 2015 11:11 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
JKWood
Jul 28, 2015 03:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
