megan coilover problem
Old Dec 17, 2006
blinky's Avatar
blinky will become famous soon enoughblinky will become famous soon enough
hey guys
i have this weird loose clunking sound coming from the front driver side. i've checked the 17mm bolt on the coilover,perches and preload been checked almost everyday. and yet i still get that cluncking sound when it driving straight. kinda like something is loose. it sounds like its coming from the top mount. but everything is tight? i dont see any oil coming out from the coilover. so im guessing its not shot. can anyone suggest other possiblites? i've checked everything. still get the clunking sound.only when im driving and when it picks up little bumps on the road. no spring binding sound when im turning or anything? please help me fellows!!! cuz if i can't solve this problem. my coilovers are gona to the dump and just going to put back oem shocks and springs
Old Dec 17, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
I'm the dump J/K did you check plastic cap on top of the spring... Thats what mine was doing..
Old Dec 17, 2006
blinky's Avatar
you mean that plastic o-ring? there is but it looks like its squished to me. could that be the problem causing the coils to make clunking sound?
i've had these coils for a year and a half.. and this problem just started 3 weeks ago.. when i had to drive over some icey roads..
Old Dec 18, 2006
mr.rowdy's Avatar
Thats what i thought it may be but if you have had them on a year and a half then sad to say i bet it is blown....imo
Old Dec 18, 2006
blinky's Avatar
yah theres this other thing that i noticed that my steering wheel is slightly turned to the right a little bit. do you think this whole situation is just an alignment problem, that would cost it to make clunking loose sound/
Old Dec 18, 2006
ragingSPAM's Avatar
I just burnt my tongue
uhm...i think the clunking is from having the top mount backwards
Old Dec 18, 2006
blinky's Avatar
what do you mean by that? its been on the car for 1.5 years no problems then with the recent dump of snow and ice. that's when all these problems came up. someone help me.. really close on just throwing these coils on the garbage and just put back the stocks.. HELP ME!!!!
Old Dec 21, 2006
TeLLy's Avatar
Yes, it's an Acura EL
Sorry to be tardy to the party. Perhaps the pillowballs are worn? I'm not really sure because I've had the clunk due to loose perch ring thingy and it clunkwed when turning too, which is not something you're getting. Also even though it sounds like the clunk is coming from up top, be sure to check ball joints and tie rods. A killed ball joint will clunk.
Old Dec 21, 2006
blinky's Avatar
yah just checked the balljoint and tie rods. still looks good. my cars an 05 EL with 28,000kms. everything else looks good. so pretty much the pillowball is worn out.and it cost 388cdn for a replacement one. it was fine before it snowed. then i drove with with snow then ice freeze then snow again.after all those icey roads it screwed them up
Old Dec 21, 2006
TeLLy's Avatar
That's really funny it did that, I've had my Megans about as long as yours through winter and they're still going strong. I wonder if a pillowball mount from any other company's coilovers will work, considering so many of them come frrom the same sources anyway...
Old Dec 23, 2006
blinky's Avatar
yah i know. its so annoying it made that sound just after it snowed and temeprature went -15.. do you guys know if its bad drving around with a bad pillowball mount?
Old Jan 5, 2007
HondaLuver's Avatar
Its a celebration bitches!
take off the wheel and look around the shock for oil... the shock might be blown
Supramk3
Jun 11, 2015 11:13 AM
luukass
Dec 14, 2001 06:27 PM
deception420
Dec 6, 2001 02:31 PM
KOPSEAL
Nov 25, 2001 12:24 AM
Flatlander
Nov 16, 2001 05:38 PM
