Koni Yellows?
Old Dec 1, 2006
loosha808's Avatar
loosha808 is an unknown quantity at this point
Koni Yellows?
I have a question regarding installation of the rear struts on a 2004 civic. I know it's been covered before but from what I have been reading most posts say that it should be a simple install with just taking out the stock struts and putting in the new koni's. But from what my friend has been telling me, I think he said he would have to drill larger holes in the strut mount to make the struts fit. Is that true? Or do I have the wrong struts? I'm pretty sure that they only make one type of rear strut for 2001-2005 civics and only the fronts have different sizes. Also, do all 2004 civics require the 55mm Koni inserts and not the 50mm?
Old Dec 2, 2006
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Check this out http://www.hondatuningmagazine.com/t...ion/index.html
I'm pretty sure all 04s/05s are 55mm. You could always measure just to be sure.
Old Dec 2, 2006
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
i remember boilermaker made a post regarding that the 01 uses 50mm, 02's were mixed, 03+ were most likely 55mm.
i have a 03 and uses 55mm. and you're correct on the rear struts part. but like mister said, its better to check yourself to be safe.
Old Dec 2, 2006
loosha808's Avatar
so i shouldn't have to make any modifications in the rear when installing the rear struts?
Old Dec 3, 2006
Correct
Tedverseti
Apr 23, 2020 01:45 PM
jammer48
Oct 4, 2018 10:04 PM
Tedverseti
Sep 29, 2015 05:41 PM
beanhead
Sep 24, 2015 12:04 PM
MamaBear2015
Sep 4, 2015 09:04 PM
