swaybar combo question.
Old Nov 20, 2006
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
currently on my car is 01 civic front sway bar(25.4mm) and rear rsx-s (19mm). and the rear goes out when i take hard turns on on-ramps.
i was wondering if anyone has 01 civic front sway (25.4mm) w/ rsx-r (22mm)...how does it feel? does it feel neutral? any inputs would be awesome.
Old Nov 20, 2006
ronaldo9's Avatar
I'm not a suspension guru like ZZyzz i think his name is but I'm pretty sure you will oversteer MORE with the 22mm compared to the 19mm rear sway. Also, how fast are you taking turns? My rear goes out too when I push it hard and I'm on 15.9mm front and 17mm rear sway.
Old Nov 20, 2006
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
^^Correct.
Civic_Racer9 are you lifting off the gas through the turn or braking when you turn in? Either one of those usually make the back end want to step out.
Old Nov 20, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
zzyxz or something lol well he told me if you daily drive and don't want body roll, then the best combo is 25mm front and 19mm rear, so thats what i did which i will be getting 25mm front today or tomorrow. can't wait!!
Old Nov 20, 2006
Da1lyDr1ver's Avatar
i had this set up for a little bit. like everyone said, you'll experience more oversteer. so, your rear end could potentially kick out a little more if you're already having problems as is.
i swapped out the front swaybar however for a Progress 27mm. this made the car more neutral again, but stiffer all around.
Old Nov 20, 2006
i can go around 50mph around the circle on-ramps before my back goes out. hmmm interesting...ok ill look into stiffing up the front more
Old Nov 20, 2006
kornsined's Avatar
I find my rear can kick out a bit with my 15 mm front 19mm rear combo. I'm thinking about stiffening the front with a thicker bar. Might trade with someone on the site here. My wife's 01 corolla has the rear kick out so easy. I swear it has no sway bars (never checked). Never was able to find any either.
Old Nov 20, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its a balance. You gotta match it with the springs. If you're oversteering with a 19, definitely don't go out and get a 22. I'd leave it, or drop down to an Si 17mm bar.
Stiffer springs will probably necessitate a stiffer sway bar to keep up. Plain ol' lowering springs don't need the big'uns.
Old Nov 21, 2006
kornsined's Avatar
yeah I noticed that with my stock and tein H-techs. Both are fairly soft.
Old Nov 21, 2006
i'd also say look into getting better tires.
Old Nov 21, 2006
ES Civic01's Avatar
ES Civic01 is an unknown quantity at this point
I have an ES civic with an EP3 type r suspension 22mm front sway bar and 22mm rear sway bar from DC5. it over steer a little bit but negligble. I'll be testing my set up this coming Decemebr at a Racing Circiut.
Old Nov 21, 2006
burke420's Avatar
The World Is Yours!
i use the progress sway and tie bar all-around. its pretty stiff with the KYB AGX on stiff too. i can take all on/off ramps at 50+ mph. plus on top of my tires i have, make a great difference too! but i have more understeer than oversteer
Old Nov 22, 2006
im lookin into buying progressive front sway bar. but ihave eibach sportline w/ new tokico blues/ and bfgoodrich tires
Old Nov 22, 2006
TemjinX2's Avatar
Yeah i agree with some of the others. You should mention what kind of tires you have as well. If you have crappy tires, that is probably the reason your back is breaking lose more then sway bars.
For handling, the 16mm front and 19mm rear is the best from the setups i went through. 25mm 19mm is the best for DD. its the combo i went with. Even with the 25mm 19mm setup, I could up to 65mph at a 45 to 60 degree angle before i feel the back coming loose.
Old Nov 23, 2006
Zzyzx's Avatar
Autocross Junky
1st off, when in the turn is the car starting to oversteer and what as a driver are you doing when it happens? such as are you on the trottle, on the brake ect ect ect...
Other wise you've got a couple of choices here, 1st thing I'd try would be to tweak my dampers, assuming you have adjustible dampers. Try stiffining the front and or softening the rear.
If you dont have adjustible dampers, and are looking to spend some $$$ on yoru suspension, pick up a set of Konis, Tokico d-spec or one of the other adjustible dampers. they are well worth it as a good set of dampers are paramount to makeing your car handle its best.
From there I'd check your alignment and optimize it. or if you are unable or unwilling to get adjustible dampers, go straight to your alignment. For a car thats oversteering I'd be looking to increase the static negitive camber on the rear and or reduce the static negitive camber on the nose. Also, check to make sure that you have no toe out on the back of the car, as that will cause oversteer. you may want to add a touch of toe in to help stablize the car (toe in on the back).
after that, then i'd start looking to alter my anti-roll bar rates. and in this instance you have two choices. either stiffin the front bar, or weaken the rear bar.
have fun and happy tuning.
Old Nov 23, 2006
goodtimes's Avatar
reped for some good ****... does anyone know what sn and sa means b/c i know that sway bars either come hollow or soiled. The reasion im askin i have a set of eibach sways there (front) 26mm sn and (rear) 16mm sa
thanks
Matt.
Old Nov 23, 2006
etc etc etc etc etc...
yey, zzyzx finally replied, btw.. i just installed the 25mm front sway bar from 01 civic (so, 25mm fsb 19mm Rsb) damn it sure does feel nice now! thanks for the advice agian zzyzx.
Old Nov 27, 2006
goodtimes's Avatar
bump for my ?
Old Nov 27, 2006
Zzyzx's Avatar
Autocross Junky
The SA and SN is probably some proprietary lable that Eibach uses... i.e. it probably means nothing to us.
Tedverseti
Apr 23, 2020 01:45 PM
IronFist
Sep 25, 2015 07:13 PM
pilebuck13
Sep 21, 2015 10:45 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
