PLease answer this question for a buddy of mine
Old Mar 6, 2005
renzo626's Avatar
renzo626 is an unknown quantity at this point
I hate to beat the dead horse but I've been out the loop since my 4th gen ZC bit the dust.
My friend has a 2004 civic EX 4dr.
1) will these wheels below fit in 19"? (or any 19's for that matter)
2) What suspension setup (strut/spring) would you guys recommend to eliminate that fender gap. Daily driver. Money is an issue. From my reading on this board this drop would have to be about 1.75-2" right? Would it cost less than 600?
Old Mar 6, 2005
QBoi's Avatar
Those are 5-lug. Civics come in 4lug
Old Mar 6, 2005
robbclark1's Avatar
Retired suspension supermod.
19's will fit, but you can't lower that low. Eibach prokit/tokicos or some teins set at max height should do the trick. There is little chance that you will be able to drop the car 2" with 19" rims. I also suggest getting the rear fender well plasma cut or rolled because he will probably scrap the tires.
Old Mar 6, 2005
renzo626's Avatar
See, thats the kind of input I needed. Thanks Robbclark1.
Qboi, that was a quick pic I found of that wheel, not the exact wheel I was going to put on, but thanks for pointing out the obvious.
Old Mar 8, 2005
VNlilMAN's Avatar
The Standard One
actually 19s with a 2" drop should fit...
I'm running 215-40-18s which are about the same size as 215-35-19 and i'm dropped 2.5". alignment is within spec and everything...
Only problem is, his car is a 4 door.. most springs are made to fit coupes so your very limited to choices...
I would say neuspeed sports(for 4 door), about 1.75" drop... should leave you with like a 1 finger gap all around or so
You dont HAVE to get struts. Yeah its recommended and it'll ride better but the stocks should last you awhile since its only a mild drop.
Old Mar 9, 2005
MarylandEcstasy's Avatar
You cant spell CRAP without APC
MarylandEcstasy is an unknown quantity at this point
maybe get a set of GCs since its a sedan. I've heard stories of people with 19s that can only turn a certain amount until it starts rubbing.. 18s would do the trick if you ask me
EliseKStewart
Jul 15, 2015 11:11 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
