Torque specs for suspension
Old Oct 2, 2004
IRockTheSohc's Avatar
IRockTheSohc is an unknown quantity at this point
i'm about to install my Skunk2 rear tie bar and also my RSX 19mm sway bar and i have yet to find out what the torque specs are for both bars. if anybody knows it would help me out a lot
Old Oct 2, 2004
robbclark1's Avatar
Retired suspension supermod.
searching > you
http://www.7thgencivic.com/forums/sh...ght=torque+lbs
Old Oct 2, 2004
88AccordDX's Avatar
Freedom costs a Buck o'Five
88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute88AccordDX has a reputation beyond repute
Ouch! hahah
Old Oct 2, 2004
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
is that the specs for the rear tie bar ?
Old Oct 2, 2004
robbclark1's Avatar
no, that is the control arm bolt. Just tighten that to about 70lbs. It isn't gonna fall out. Once it is in, it shouldn't wiggle out. 70lbs should be enough 80 if you really want to tighten it. don't go crazy though. Hand tight with a ratchet is fine too.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
Elciteeve
Sep 28, 2015 12:40 PM
czarlun
Sep 14, 2015 08:16 PM
