quick question
Old Sep 8, 2004
NaSh123's Avatar
NaSh123 is an unknown quantity at this point
quick question
hey guys is the engalls front and rear camber kit a good choice? or a different camber kit would be better? its for a 1.5 inch drop
Old Sep 8, 2004
Mr.Modify's Avatar
it's fine....
Old Sep 8, 2004
NaSh123's Avatar
ok cool thanks
Old Sep 8, 2004
jttegx's Avatar
OMNES AD UNUM
as long it does what it does, it'll be fine.
i have spc rear camber and works perfectly fine so far. ingalls has a good reputation too. not sure about obx =|
Old Sep 8, 2004
NaSh123's Avatar
just to make sure....this setup would work and is all i need to do to run everything perfectly correct....Eibach 1.5 Sportline Springs, Koni Shocks, the engalls rear and front camber kit, then at the end get an alignment and i should be fine right?
Old Sep 8, 2004
flotsamm's Avatar
Should be fine. I have basically the same setup as you mention except I'm using and SPC rear camber kit only. I didnt see the need for on up front since Sportlines dont drop that much.
Old Sep 8, 2004
streetglower's Avatar
Wow 3 of us with the same setup, you kick ***.
Yes you will be fine man.
Old Sep 8, 2004
alienmeatsack's Avatar
alienmeatsack has a spectacular aura aboutalienmeatsack has a spectacular aura about
So really unless your drop is extreme in front you dont need a camber kit up there at all?
I noticed on my stock rear that the wheels seem to lean in a tiny bit, so I assume the rear def needs camber adjustment when droped even say 1.25-1.5"?
Old Sep 9, 2004
cubanmike26's Avatar
As long as you modify your car from your stock height, you will always have negative or positive camber unless you correct it with a camber kit. Depending on the Camber's degree you will/won't need a camber kit, but even if camber is affected only a little, keep in mind that sooner or later your tires will wear out uneven.
Old Sep 10, 2004
My future set up: Eiback Sportlines+Koni+SPC rear onlny.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
