quick question about preload
Old Aug 25, 2004
KalliGarri's Avatar
A.K.A BlackCar --- Not From Califorina!
KalliGarri is on a distinguished road
when u tighten ur springs.. preload it.. does that lift ur car or lower it more?
Old Aug 25, 2004
2k2redcivic's Avatar
2k2redcivic has a spectacular aura about2k2redcivic has a spectacular aura about
if u tighten your springs it will lower your car.
tightening (compressing) the spring will in tern make the over all travel of the spring less.
if i understand what your sayin right.
you shouldnt use the term "preload" that refers to compressing a shock before opening it all the way up (jumping a bike or quad like that)
Old Aug 25, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
No, preloading springs does NOT alter the height. All you're doing is compressing the spring in relation to the shock so its effective rate starts out higher.
This is unless you're referring to coilovers where preloading is the method of lowering or raising the car (Tein SS or Basic, etc.....)
On coils like JIC, Tein Flex, Hayame, etc... with adjustable length shocks, the preload should not lower the car.
Old Aug 25, 2004
robbclark1's Avatar
Retired suspension supermod.
such a smart enginerd There is one exception however. In coils with adjustable mounts like JIC Tein Flex, if you up the preload (just in the front) too much where the spring is not loose when you jack up the car, it will start to alter the height, but not severely.
CraigW
Aug 18, 2015 07:06 AM
civic98?
Aug 13, 2015 01:32 AM
Strycker
Aug 2, 2015 08:40 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
NoobyKid
Jul 13, 2015 07:53 AM
