Rear hayames noisy
Old Jul 28, 2004
halflife's Avatar
halflife is an unknown quantity at this point
Rear hayames noisy
There is some noise coming from my rear hayames when going over bumps, sounds like the springs coils are hitting each other.
has anyone experienced this? COuld it be my install?
Old Jul 28, 2004
518's Avatar
518
518 is on a distinguished road
The locking perch is loose. And they tend to come loose every now and then. Like every three days and depending on the road you travel. The worst road you travel, the bigger chance of it getting loose.
I really wish you the best of luck...
Old Jul 29, 2004
halflife's Avatar
Well that would explain it since I live in NY. Has anyone put teflon or something on the treads to stop that?
Old Jul 29, 2004
halflife's Avatar
Ok, NOt a suspension expert, which one is the locking perch?
Old Jul 29, 2004
TeLLy's Avatar
Yes, it's an Acura EL
The top two nuts have to be tightened against each other. Use a rubber mallet or hammer on the spanner wrench to really tighten it up.
I thought my Hayames were fuqtup cause of this noise I kept hearing whenever I hit a bump. Turned out to be my exhaust pipe hitting the friggin rear sway bar.
Old Jul 29, 2004
robbclark1's Avatar
Retired suspension supermod.
Most coils make noise. You should hear mine!! Blah!
Old Jul 29, 2004
TeLLy's Avatar
That's true - if they were totally noise-free, they'd be stock, ha ha.
Old Aug 2, 2004
halflife's Avatar
I adjusted everything this week and the ride is better. I think i had too much preload on the driver side rear. My front passenger side I could move the spirng up and down 1/2 to 1 inch...oppss. So all is adjusted for now. Still not 100% satisfied with the ride quality but it is night and day from installation to proper adjustments and a wheel alignment. Still think I may dump these for some Tokicos since I have nuespeed race springs already.
GolNat
Nov 27, 2018 03:32 PM
Scout1
Oct 5, 2015 01:33 PM
Sep 27, 2015 11:33 AM
czarlun
Sep 14, 2015 08:16 PM
Josh 1973
Sep 7, 2015 10:10 AM
