SDAS Suspension help
Old Apr 28, 2004
speedcreations's Avatar
speedcreations is an unknown quantity at this point
I have a couple of problems
1. SEVERE DRAG ASS SYNDROME
The driver side rear tire sags/tucks more than the other side. I recently put new shocks/struts on the whole car. I also just installed GoldLine springs. Any suggestions?
2. Road Noise. It's not the tires b/c it's done it through 3 different sets of tires. I use to have sh|tty coilovers on and I don't think the ppl who installed them put the suspension back together right, so when I installed the springs I assumed it was correct. Anyway, it also could be the rotors, but it sounds more serious than that. Is it possible to bend a drive shaft? B/C when I start slowing down to stop, it bounces a little bit, kinda like when you have a buldge in the tire.
Nasty on bumps and not aligned...
Where should I start??
Old Apr 28, 2004
streetglower's Avatar
Do you have aftermarket struts?
Old Apr 28, 2004
Nope, just new OEM ones from Honda
Old Apr 28, 2004
VNlilMAN's Avatar
The Standard One
the sagging is probably because of the springs
the noise, eh hard to say
Old Apr 29, 2004
Logan3024's Avatar
If your goldlines are sagging call them and they will replace it for you.
Road noise, sounds like a rotor to me to. did you have it resurfaced last time you installed pads? Or i may be warped. Or maybe a bent rim?
Do you know the model number of your goldlines?
Old Apr 29, 2004
Don't have the model #. A shop ordered them adn put them on. I could probably find out. Would they replace them?
I'll probably just buy new rotors and see what happens..I'm sure I need them
Old Apr 29, 2004
Logan3024's Avatar
Yes they will replace them for you. Call 877-671-9752.
Tedverseti
Apr 23, 2020 01:45 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
