Will my wheels fit?
Will my wheels fit?
I just bought 17x7 Konig Holes for a 2001 Honda civic coupe and planned to put 215's on them. But a local tire guy i know says that if i put those on i can't lower my car. Is that true?
I only plan to lower my car between 0.8 in and 1.5 in. Will that cause a probelm>? Will the tires rub anything? THanks for your help.
he is full of crap. they should fit. you MIGHT rub if you go to low, but you can be corrected with slight negative camber. I really don't think you will have a problem going 1.5" down, as long as that is a 1.5" settled.
k
Search and Learn
you will never rub with prokit drop.
what size tire are you looking at? 215/45/17 or 215/40/17
i think 215/40/17 will be just fine with prokit and sportlines.
i had no rubbing with 215/45/17. dropped about 2 with tein ss fullcoilovers
yea man definitely!! you will be A - Okay...i got 215/40/18's with about a 1.75 to 2" drop on goldlines and i have no rub what so ever and i'm very satisfied with the drop!! now just gotta get the rest of my kit!!
k
I was going to go with 215/45/17 cus their overall diameter was closest to my stock tires, to prevent change in gear ratios and speedometer readings.
I did 215/40/17 and I'm dropped on eibach sportline's, never rubbed at all, still have a slight amount of wheel gap, and the speedo is supposdly off by 3% which isnt that much...
BootyDo
Jun 21, 2016 03:45 PM
jferristx
Jul 8, 2015 10:09 PM
BootyDo
Jul 7, 2015 06:06 AM
