Rear Camber Kits
Old Oct 9, 2003
warmboi504's Avatar
warmboi504 is an unknown quantity at this point
Rear Camber Kits
I'm looking for rear camber kits and I was wondering where I could get a pair for the cheapest price. Doesn't really matter who makes it.
Old Oct 9, 2003
sffree's Avatar
sffree is an unknown quantity at this point
It may... I'm investigating a current noise problem that I think (thanks to insights from 7thgencivic.com) is camber kit related.... make sure the installer is experienced and doesn't install while the car is jacked up... otherwise it will twist up the bushing and cause a noise like me... at least I hope it's as simple as that. Otherwise... disregard my ramblings.... I wonder if the ingalls kit sold on neuspeed's site is more proper for the civic... or if it even matters at all...
Old Oct 9, 2003
civicvtec1ps's Avatar
Search and Learn
http://spc.danscreations.com/
spc
Fronts: These cam bolts allow both positive and negative camber
changes up to approximately 1.75 degrees. They replace the factory strut/spindle bolts on each side of your ride.
01-02 14mm
03 16mm
Rears: These camber control arms replace your factory ones, and
allow adjustments in camber anywhere form -4.00 degrees to +6.00
degrees.
ibtl
Old Oct 9, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
how would u go about installing a control arm without lifting the car up??? that makes no sense spc is a pretty good from what i hear on the board but u should do a search or the search ***** will be all over u....goto tornactive.com he sells revo and spc ones prety cheap too
Old Oct 9, 2003
DroppIN808's Avatar
DroppIN808 is an unknown quantity at this point
on my accord my rear camber kit used to make noise cuz the bushings needed to be greased, then once i did it was all good.
Old Oct 9, 2003
4bangin's Avatar
i got eibach rear and front and have no problems whatsoever. kinda expensve but whatever. my dad bought em for me so i dont care.
GolNat
Jan 12, 2021 09:06 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
chrisjackson321
Jul 12, 2015 03:00 PM
