Did I mess up my suspension?
Old Sep 17, 2003
2k1civic's Avatar
2k1civic is an unknown quantity at this point
Well to sum up what happened:
Drove over pot hole.
Bent 18" Rim rear driver side.
Drove on donut for about a month awaiting discontinued rim replacement from canada.
Now, driver side of car is lower (less wheel gap) than the passenger side. Since the donut was so much smaller it made the car kinda lopsided while I was driving on it.
Did I do permanent damage to my suspension? I have eibach pro-kit spirings and stock struts.
Thanks in advance for any help/suggestions!
Old Sep 17, 2003
flotsamm's Avatar
How much lower are you now on the drivers side? I know that the drivers side from the factory is a little lower, like a 1/4".
Old Sep 17, 2003
2k1civic's Avatar
well i just went and measured from top of rim to fender on passengar side is 4" and on driver side is 3.5" I mean its pretty noticeable to me because it wasnt like this before the incident.
Old Sep 17, 2003
2k1civic's Avatar
can anyone out there help?
Old Sep 18, 2003
flotsamm's Avatar
Hrmm.. maybe find a flat road and measure from the ground to the top of the fender on each side. Make sure you measure in the same spot. Check the tire pressure on each tire also. Maybe stick the spare on the other side for month and then see how it measures up.. heheh
Old Sep 18, 2003
2k1civic's Avatar
Thanks Ill remeasure this weekend somewhere flat and update this post
Old Sep 18, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
no offense man, but I remember your other post where you asked if it was OK to dive on the donut for a long time, which you are only supposed to use the donut in an emergency. Anyways, you can't blame anyone but yourself.....
Old Sep 18, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
i dun think ur suspension is messed up...get that rim off, and realign your car. I drove on a lopsided wheel (****ing goodyear) for months, and my steering wheel was on a 15 degree tilt when I drive straight. When i got my car aligned, the cambers were off by 4-6 degrees! the guy at the shop was shocked... but my suspension is fine so far...i have eibach ground contols with stock struts. Good luck man! oh, and make sure ur struts didn't pop...if they did, take em in to dealership and have em replace it under warantee (if you're still covered that is)
Old Sep 18, 2003
2k1civic's Avatar
Thanks for your post.... but I wasn't looking to blame anyone. Im not like OH NO did i mess up something. I realize it wasnt good to drive on the donut for that long but I didnt have a choice. Im just asking for some professional opinions on what may have been damaged and caused the difference in wheel gaps thats all.
Old Sep 18, 2003
sihotan's Avatar
sihotan is an unknown quantity at this point
go to a alignment shop. get them to give you a computer readout of your car as is. maybe that might help
Tyler93
Mar 20, 2016 09:03 PM
Munzy
21
Oct 7, 2015 07:48 AM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
Dsmak
Sep 10, 2015 08:30 PM
