Will bigger tires fit?
Old Dec 28, 2022
Sabin-_-P's Avatar
Sabin-_-P is an unknown quantity at this point
I have an 02 Civic LX with 180/70R14 steelies and I want to change them to my nicer rims/tires from my old Accord which are 195/65R15, will I have any interference or other issues besides spedo error?
Old Dec 28, 2022
Harry Hemi's Avatar
Harry Hemi is an unknown quantity at this point
Re: Will bigger tires fit?
Put one of the 15" wheels next to the 14" ones. If the lug pattern is the same and they are wider and taller, you will lose power and possibly rub when steering. Check if they are the same width and then check the offset. I do not know if the civic offset is the same as the Accord offset, but if its way off you might have issues.
Throw one on, see what happens.,
Old Dec 28, 2022
GolNat's Avatar
Prelude Owner
What year Accord? Might be 5 lug.
Use a tire calculator to determine speedo error. Wheel offset is usually stamped on the back of the rim. OEM wheels are typically close to the same offset.
Old Dec 28, 2022
Sabin-_-P's Avatar
It's a 2000 Accord 4 lug, it fits on the civic I just wanted to check before I test drove.
Old Dec 28, 2022
Top menu, Tools
Old Dec 28, 2022
Colin42's Avatar
I thought 4 bolt accords were 4 x 114?
Old Dec 29, 2022
FRSam's Avatar
Click Here
You would be correct. Something is off here
Lukarlov
Jul 17, 2020 01:24 PM
Jcapyammi3
Dec 11, 2011 12:36 PM
mdawg
Wheels and Tires
May 28, 2007 03:11 AM
InOvAtStyL
South Cali
Mar 31, 2005 07:33 PM
jongreenway
Apr 11, 2003 04:02 PM
