Will these rims, tires fit my civic?
Old Mar 6, 2003
jongreenway's Avatar
jongreenway is an unknown quantity at this point
Motegi Mr7 16x7” rims with Nitto 205/50/16 tires
Will they rub? Do they fit fine on a 2k2 lx sedan?
Old Mar 6, 2003
GanariGuY's Avatar
GanariGuY is an unknown quantity at this point
yes i believe it will fit ur car.....
50's are about stock size.....
Old Mar 6, 2003
I don't understand the sizing for tires, but if 50 is the same size as the stock, and the rim is 16" instead of the stock 15", then won't the whole wheel be bigger?
Old Mar 6, 2003
GanariGuY's Avatar
yes the wheel will be bigger... but the gap between the tires and the fender is large....
Adding an inch will still leave alot of space
Old Mar 6, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
I believe he meant that the 205/50-16's you were talking about were the same overall diameter as stock size.
Go w-a-a-a-a-y up toward the top right corner of this forum page to the "tire calc" link. When you get there, put in your stock tire size vs. the 205/50-16 (actually, you can see that it is one of the recommended "plus" sizes listed there). You can see that it is a pretty good match, with not much speedometer error. (That shorter sidewall on the 16" tire makes up for the larger 16" diameter wheel, but the overall diameter pretty much stays the same[IMG]i/expressions/face-icon-small-smile.gif[/IMG])
There should not be any rubbing with a 205 mm width -- read the other thread going right now about all the people that are running 215's with no problems.
Old Apr 11, 2003
CivicEnvy2001's Avatar
CivicEnvy2001 is an unknown quantity at this point
They will fit just fine. I have the Motegi Mr7 17's and I could've gotten an 18. So 16 will be a little small.
Old Apr 11, 2003
VNlilMAN's Avatar
The Standard One
ya one misconception is bigger the wheel = bigger tires = rubbing.
you have to remember when you get bigger wheels, you get thinner/low profile sidewalls to make up for the bigger wheels. as bigdaddy said, you want to look for the OVERALL tire diameter..(n ya width as well)
bo_red
Apr 23, 2015 10:09 PM
SpoonSportsd17a
Nov 19, 2001 09:26 AM
locozoko
Nov 4, 2001 08:44 PM
DC5@EM2
Nov 4, 2001 08:42 PM
