Resurface rotor or not with current thickness.
Old Jul 24, 2013
abhijitz's Avatar
Member
abhijitz is an unknown quantity at this point
Model : 2003 Honda Civic LX
Front Rotor Thickness Min Spec : 0.75"
Front Rotor Current Thickness :0.80" [Certain areas recorded 0.801, Certain 0.804, Certain 0.803]
Front Brake Pads Min Spec : 1.5mm
Front Brake Pads Current Spec : 3.26mm
Issue : steering wheel pulsation during heavy braking. wheels have been re-balanced. alignment done to spec.
So, i am not sure if my rotor is warped, i dont think at 1/1000" it can be considered as warped. Do you guys think there is enough meat left to perform one resurface? [It was never done before]. With a resurface how much material is shaved off?
Old Jul 25, 2013
CraigW's Avatar
Re: Resurface rotor or not with current thickness.
Have they been machined at all ? Make sure it is not from rear (press and hold parking brake button and work them on and off at 20mph and see if you get pulsing)
I no longer get rotors machined, simply replace them at 2nd set of pads. And use OEM.
Old Jul 25, 2013
abhijitz's Avatar
Member
No, they have not been machined at all.
Ok, i will check this step and report back.
Old Jul 25, 2013
CraigW's Avatar
^^ likely the rotors, out of round drums were common on my past Corollas.... not so much with Civics.
The test will let you know pretty quick.
3.26mm is certainly not much pad left either.
Old Jul 25, 2013
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
If you think the rotors might be warped you should be more concerned with runout than thickness. The thickness doesn't change from the warping but the runout (distance of the rotor surface from a fixed point) does. Thickness becomes an issue when they turn the rotor. They have to remove material until the warp or runout is eliminated and they can not go below the min thickness. How much material they remove depends on how badly the rotor is warped.
Old Jul 25, 2013
abhijitz's Avatar
Member
I dont have a dial indicator to measure the runout. The warpness (if any) is not much that is visible with the eye and a vertical scale perpendicular to surface.
Old Aug 3, 2013
sl33pyriceboi's Avatar
I'd get them resurfaced. Any reputable shop will tell you if they can't do it due to the thickness (liability). Depending on which pad I use, I get my rotors resurfaced anywhere from 1-2 times for its life.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
Bikergofast
Sep 12, 2015 01:36 PM
NaturalSelectio
Sep 6, 2015 06:59 PM
rainman15
Sep 6, 2015 11:10 AM
General 7th Gen
Jul 9, 2015 10:17 PM
