Lug nuts questions
Lug nuts questions
hey, recently i've purchase a set on enkei wheel from a local guy. apparently oem lug nuts doesnt fit aftermarket wheel. if it doesnt fit then what size do i need to get or which ones? Thanks
Re: Lug nuts questions
you need "tuner" lug nuts which are pretty common. just check ebay and the size for most hondas is M12x1.5
muteki is a pretty good and cheap brand.
^yea what gearbox said...
but the proper name for them is Acorn style lug nuts because they have a 60 degree angle.
the oem ones u have are probably the ball style lug nuts.
Live for the Twisties
They can also be called spline drive lug nuts.
Most wheel shops should have the cheap mutegi style ones available for less than $30, but if you want a bit of flash you can get high end nuts that run anywhere from $100-500.
if u want high end lug nuts that wont blow a hole thru ur pocket, take a look at BLOX forged aluminum. quality and lightness is the same as the RAYS/VOLKS just not as expensive (ur paying for name brand at that point, plus they are JDM.....yo)
civic98?
Aug 13, 2015 01:32 AM
17
Jul 23, 2015 11:48 PM
califcamper
Jul 21, 2015 10:34 PM
NoobyKid
Jul 13, 2015 07:53 AM
