Rear Brake conversion thread
Old Mar 31, 2005
  #61
etdigitalis's Avatar
etdigitalis should not be trusted
Rear Brake Conversion //Revised Parts List//
First off, I'd like to thank RiceBuRNeR for his original post with the parts needed for this project. However, for those of us who have attempted this DIY with new parts based on his list (instead of finding the already assembled parts in a junkyard somewhere), you know it was missing the hubs... and unless you like driving around with rear rotors only attached by lugnuts and calipers, this is not good
I have not completed this DIY yet. I ordered the parts before realizing the problem and have since updated my order to include the missing parts. I've seen other forums briefly touch on this matter, but to save the pain of meticulously searching through ancient forums, I've updated the list with new prices from Majestic Honda (www.hondaautomotiveparts.com):
Component Diagram - Rear Brake (Disk)
1073308 004 2 BEARING ASSY., RR. HUB UNIT 237.32
1073309 007 1 CALIPER SUB-ASSY., R. RR. 158.36
1073310 008 1 CALIPER SUB-ASSY., L. RR. 158.36
1082874 006 2 DISK, RR. BRAKE 73.12
1083728 009 1 PAD SET, RR. (9CLP-14S,D6272) 43.99
1095008 028 1 MUDGUARD, R. RR. 5.01
1095009 029 1 MUDGUARD, L. RR. 5.01
33602 039 2 NUT, SPINDLE 12.40
Component Diagram - Rear Lower Arm
1073334 001 1 KNUCKLE, R. RR. 149.16
1073335 002 1 KNUCKLE, L. RR. 149.16
Component Diagram - Parking Brake
1095011 005 1 WIRE B, R. PARKING BRAKE 26.18
1095012 008 1 WIRE B, L. PARKING BRAKE 24.67
Component Diagram - Brake Lines (ABS)
1094990 003 1 HOSE SET, R. RR. BRAKE 25.71
1094991 004 1 HOSE SET, L. RR. BRAKE 25.71
Total cost: $1094.16 + S&H
Notes:
Knuckles come with spindles and bushings
Calipers come as a full assembly with all seals included
You can re-use your old spindle nuts, but because it's necessary to bend a part of them to lock/unlock them, Honda recommends you replace them.
Brake lines have been included, but I strongly recommend avoiding rubber and upgrading to stainless. www.Tirerack.com sells a set of Goodridge G-Stops for $127. And if you plan to sub the pads for aftermarket ones, you may still need to buy shims.
If I have missed anything, please let me know so I can update this list.
I hope this post serves someone well.
Admins: Please update the FAQ. Thanks.
EtDiGiTaLiS.
Last edited by etdigitalis; Apr 7, 2005 at 04:57 PM. Reason: Added spindle nuts and updated pad set qty
Old Dec 19, 2007
  #62
civiclowlife's Avatar
civiclowlife is an unknown quantity at this point
Re: Rear Brake conversion thread
I have a honda 2004 vp without abs shouldn't I be worryed about my wheels locking up?
Old Dec 19, 2007
  #63
tfnaaf's Avatar
BLDNPSI Mod
why should you be worried?
Old Dec 19, 2007
  #64
spoonEM's Avatar
omgwtfbbq mod.
Ive been running without ABS for a while now...never really had any problems.
Old Feb 22, 2010
  #65
EM2 Rookie's Avatar
EM2 Rookie is an unknown quantity at this point
Re: Rear Brake Conversion //Revised Parts List//
Notes:
EtDiGiTaLiS.
i have a 02 ex i just buy whats listed strip off the drums and replace the lines and install the disk? and bleedin them of course
Old Mar 12, 2010
  #66
shadowz_2_2003's Avatar
shadowz_2_2003 is an unknown quantity at this point
Hi, I cant say this wasn't mentioned already for sure, but I have an 04 civic coupe, the canadian si, what car would I be able to use the parts from so they would fit properly, would an rsx work or is there something better? if I could swap them with a set having the same bolt pattern it would be easier for me and save me the time and money of swapping out the front brakes as well. Thanks
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
97-DX-Lover
Jun 14, 2015 06:07 PM
Broadbeb
May 14, 2015 09:49 PM
CivicHX01
25
Nov 18, 2003 09:40 PM
