Rear Brake conversion thread
Its a celebration bitches!
well if you go to honda you have part #'s... and you can also get these parts off of a totalled si or from some one that has upgraded to 5 lug...
keep all your bolts, and the abs sonsor off ur car... you will need to change all the stuff above... if its not listed, just keep your original parts...
its the same thing.... all the parts in the pictures are the parts that riceburner listed, just more specific, but if you get them off a si, you just have to worry about a few big peices, because it is a straight swap....
im not sure, since si's come with stock 15 inch rims... and the rear brakes are smaller than our stock fronts... and the si's and our fronts are the same size...
quick question for hondaluver or ricerburner on the parts list posted by ricerburner the mudguards are they for the discs or are they just a part of riceburners order and the disk why do we need 4 or were they just posted twice in error ?
I doubt you could add ABS. You would need the computer, the lines, the modulator, the sensors, the wire harnessess, and install them all.
Plus you forgot to mention brake proportioning. You could use the valve from an Acura EL, which has four wheel discs.
Autocross Junky
Personally I'd avoid drilled rotors at just about all costs. (Unless I was hunting down that last tenth) and I'd avoid larger brakes also just about at all costs (unless there was no other way to get brake temps down).
Why is my vagina bleeding?
Zzyzx I guess if this exsisted you have it by now, but I'll ask anyways. Are there lighweight rotors for our cars, that are just as good as stock in terms of durability, and don't cost and arm and a leg? I remember you talking about unsprung weight and all. rotorts 30-40 pounds lighters would make a significant performance change right(because of the unsprung weight stuff you tried to explain few times but I think I was lost when I was reading your explanation)?
Where does the proportioning valve go on the car?????? I have an Si Sedan EX american and it has ABS.. so all i need is to find an acura El 2001 plus i guess to do this....
well... I've been reading this thread up and down I even printed the whole thing and I have a question... I have an 05 EX Sedan are all these parts the same for the 04-05 models? that's all I'd like to know... thanks!!!
Autocross Junky
If you are really interested in lightining your rotors... I'm sure Porterfield could build you some..
http://www.porterfield-brakes.com/rotors-custom.html
