Air Conditioning Post issues about air conditioning here
Air conditiong blowing hot air
Old May 4, 2024
Pnutt559's Avatar
Pnutt559 is an unknown quantity at this point
I own a 2007 Honda civic si 2 door, I recharged the a/c system just this morning, but its still blowing out hot air. I can see the clutch engage but shuts off and on intermittently every couple seconds, any ideas on what it could be and how to fix it? Thanks in advance.
Old May 4, 2024
Colin42's Avatar
Re: Air conditiong blowing hot air
Do you have a proper set of manifold gauges so you can see the high and low sides?
Old May 4, 2024
Pnutt559's Avatar
No I don't
Old May 4, 2024
what method did you use to fill?
did you run the engine and AC while you filled?
Old May 4, 2024
Pnutt559's Avatar
connected charge hose through the low port, had a/c on high with the circulation on. About a week ago i noticed not so cold air coming out so I just thought it needed to be recharged, something I did notice was that when I started charging the system, the ar started doing this hiccuping thing and drop rpms everytime the compressor clutch engaged
Old May 5, 2024
Colin42's Avatar
You might have over filled it
either buy proper gauges or pay someone to fix it.
Old May 5, 2024
Pnutt559's Avatar
I don't think I over filled it because i was already losing cold air before I charged it, and the gage on the bottle didn't even get to half green "safe zone"
Old May 5, 2024
Pnutt559's Avatar
The compressor kicks on, but I notice the clutch engages and disengages like every 2 seconds, can it be the compressor clutch thats bad? And can it be fixed without having to buy a new a/c compressor?
Old May 6, 2024
BrotatoChip's Avatar
Super Moderator
It's more likely that the pressure is too low/high. Like mentioned, a proper set of gauges would be helpful. Parts stores usually have a set as a loaner tool.
Old May 7, 2024
Pnutt559's Avatar
Thanks for all the advice guys, I work at an rv dealership and had one of the techs looks at my car today, turns out I did in fact over fill the a/c system, luckily nothing was damaged, even though i was careful probably not going to diy that again.
Old May 8, 2024
Super Moderator
It's a learning experience for next time. Just do a bit more research beforehand and get the correct tools
Old May 9, 2024
Pnutt559's Avatar
Yes most definitely, its fixed to a point, I am getting semi cold air on idle, not as cold as it should be, gets colder when I am driving only
Old May 10, 2024
Colin42's Avatar
Might be too low now
Old May 10, 2024
Pnutt559's Avatar
What might be too low? It got recharged after. There's got to be something else wrong with it, im thinking the condensor
Old May 11, 2024
Colin42's Avatar
If you have a leak it will get low after a bit
the condenser gets pretty hammered
Old May 11, 2024
Pnutt559's Avatar
Its already been checked for leaks, there are none, I did notice that the condenser fan isn't coming on.
Old May 11, 2024
Colin42's Avatar
Check the relay, try powering the fan directly
Old May 12, 2024
Pnutt559's Avatar
Yes, thank you, hoping to get that looked at asap
crenchy
Air Conditioning
Jan 4, 2024 05:21 PM
mrcoffee
Air Conditioning
Aug 15, 2022 04:50 PM
sbaugz
Air Conditioning
Nov 17, 2021 06:26 AM
supraman1990
Sep 22, 2011 01:22 PM
