Air Conditioning Post your questions about air conditioning here!
climate control system acting up.
Old Nov 16, 2021
sbaugz's Avatar
sbaugz is an unknown quantity at this point
2016 EX-L. My air conditioner crapped out two years ago and it was replaced under the service campaign. This past summer i started having problems again. It would not get cold. I figured it was the same problem. Local dealer wanted to charge me $300 to diagnosis. I decided to blow it off and live with it since winter was coming anyway. fast forward to now. It seems like my heat is acting up now too. No matter the temperature setting, I am getting hot air coming out of the vents. When I put the driver and passenger on different temps, the same air is coming out (hot).
Now I am thinking its not an isolated air conditioner problem. Is there some sort of thermostat that went bad? I either get super hot air (when the heat is one) or moderately cool air (when the air conditioner is on). There is no median.
Thanks.
Old Nov 16, 2021
Re: climate control system acting up.
take to a second set of eyes and get their diagnosis
come back with results (you can choose to do at later date or reject work) diagnosis fees could be less outside the dealer but might not be accurate
Old Nov 16, 2021
sbaugz's Avatar
My point was that I didn't want to pay $300 to have them diagnosis the air conditioner when it may not be that at all. Just curious if someone out there had a similar issue or know of a solution
Old Nov 16, 2021
don't think it costs 300 outside of dealer?
Old Nov 16, 2021
sbaugz's Avatar
thanks but I will wait for other advise.
Old Nov 16, 2021
Colin42's Avatar
Take it somewhere and get a second opinion
Old Nov 17, 2021
BrotatoChip's Avatar
Super Moderator
About the only other thing I can think is the blend door is jammed or broken.
stault
Jan 8, 2018 07:05 PM
supraman1990
Sep 22, 2011 01:22 PM
phil946
Jan 24, 2011 12:23 AM
MrWong
Dec 22, 2004 01:25 PM
Master
Jul 27, 2003 01:56 PM
