Air Conditioning Post issues about air conditioning here
'08 Civic AC suddenly not working
Old Jun 23, 2023
nekochen's Avatar
nekochen is an unknown quantity at this point
Hi, the AC in my car became intermittently working since May then just stopped working last week. My initial thought was to get an AC recharge kit. The low pressure gauge, to my surprise, reads near 100 psi even with the AC turned on for nearly 3 minutes. Is the compressor dead? And how much am I to expect this fix will cost me?
Thanks.
Old Jun 23, 2023
Colin42's Avatar
Re: '08 Civic AC suddenly not working
I know this generation tends to eat compressors for some reason. Are you sure the clutch on the compressor is engaging?
Old Jun 23, 2023
nekochen's Avatar
Thanks for the quick reply.
I'm not knowledgeable about the clutch, but the compressor belt is moving looking from the top of the hood.
Old Jun 23, 2023
Colin42's Avatar
Its all one belt, the clutch is the disk on the front, it should spin for a bit, then disengage, then come back on.
https://images.app.goo.gl/Vm815yiHrjcbskYS7
Old Jun 26, 2023
BrotatoChip's Avatar
Super Moderator
Might want to check the relay and also the clutch gap.
Old Jun 26, 2023
nekochen's Avatar
I checked today and found out it indeed is the clutch, it's not spinning. I watched a video saying a light tap may fix that, I'm going to try that first
My guess as to why this happened is probably because road bumps/pot holes. The clutch engaged once when I went through a pot hole for a short while then it never did again.
310civicEX
16
Feb 2, 2018 11:26 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
sdraza1
Aug 30, 2013 06:08 PM
civicbaby
Jul 15, 2011 11:38 AM
EM2Civic
Jun 13, 2004 07:59 PM
