Both fans and ac compressor stuck on
Old Jan 30, 2018
310civicEX's Avatar
310civicEX is an unknown quantity at this point
Everything was fine.. I put in some ac pro then the fans are always on and the ac pump also...and the vent selector doesn't do anything
Old Jan 31, 2018
Re: Both fans and ac compressor stuck on
If it ain't broke, keep on fixing it until it IS broke.
You did what?
Why?
What exactly is this crap you put in?
Old Jan 31, 2018
310civicEX's Avatar
Well I fixed everything on the car.. no check engine lights.. the vent selector worked normal...the fan came on at normal temperature. .. I put in AC PRO and i must have got air in the ac lines or over filled or both... now the vent selector doesn't do anything.. the ac pump is always on when I start the car...as well as both fans
Old Jan 31, 2018
Colin42's Avatar
What is AC pro? a can of freon with stop leak in it?
Old Jan 31, 2018
310civicEX's Avatar
ac pro is the freon in a can .... the climate controls are from another car, the ac compressor is from another car the system was empty and i put in some AC PRO and it it got the compressor spinning along with both fans. now all 3 run every time i start the car and the climate control vent selection wont move from foot vents..
Old Jan 31, 2018
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Should have started with this...
To properly fill an AC system you need to evacuate all the air from the lines using an AC machine, it puts a vacuum on the lines to boil out the moisture and also check for leaks. Then it adds freon and oil.
If you did not put oil in the compressor and it was dry you might have damaged it already.
Old Jan 31, 2018
Would have been nice to have this full story before thinking about what is going on.
Pull the control panel out and unplug it. See if that makes the AC stop running.
Old Jan 31, 2018
310civicEX's Avatar
I'm getting a hvac dtc code of #10. Can't find info on what that is..
Old Jan 31, 2018
For some reason I can't find it right now either.
Forum search?
Google search?
Old Jan 31, 2018
310civicEX's Avatar
10- An Open or Short in the Mode Control Motor Circuit
Old Jan 31, 2018
Okay.....Was that code present with the original HVAC panel installed?
Does the AC compressor and fans shut down when you unplug this HVAC control panel?
Old Jan 31, 2018
310civicEX's Avatar
my civic is a 2002 i do believe i swapped my MODE CONTROL MOTOR CIRCUIT out with a 2004... hopefully thats the problem
Old Jan 31, 2018
310civicEX's Avatar
the ac system was bone dry and ac compressor never came on until i sprayed the AC PRO in the system. gotta pull the switch tomorrow... hopefully that will be the solution... but still need to bleed the ac system.
Old Feb 2, 2018
310civicEX's Avatar
it was the a/c control module next to the head unit... 100% fixed
Old Feb 2, 2018
Slumpertcivic's Avatar
Awesome you fixed it. Just a bad switch?
Old Feb 2, 2018
Control panel, the bigger part with the ***** next to the radio
Old Feb 2, 2018
310civicEX's Avatar
Apparently 2002 civic climate controls cannot be swapped out with any other rear... working perfect now thank god.
Thundar
Air Conditioning
Sep 17, 2017 10:30 PM
buggerdtp
Jun 8, 2016 02:28 PM
Grimlock
40
Jun 19, 2015 08:25 PM
tolgaek
Dec 19, 2014 07:41 PM
gudoffer
Aug 12, 2009 09:35 AM
