Air Conditioning Post issues about air conditioning here
AC Comp and Dry question
Old Jul 8, 2021
imhtwo's Avatar
imhtwo is an unknown quantity at this point
So I took my car in to the Honda dealership and they replaced my AC Compressor and drier. Within 13 miles, my passenger side upper stabilizer bar come loose, bolt was gone and it was just swinging free.
Prior to taking it in, there was no sign of noise that goes with a loose stabilizer bar, popping etc. I would think they wouldn't need to take the tire off to replace the comp but I was unsure about the drier.
Where is the dryer located on a 2013 SI? I am waiting for the dealership to call me back, I am sure they will claim no responsibility. Thanks for the info. John
Old Jul 9, 2021
BrotatoChip's Avatar
Super Moderator
Re: AC Comp and Dry question
The drier is inside the condenser.
I don't see why they would have loosened that unless they were trying to lower the subframe. Not sure if that's required for compressor replacement.
Old Jul 9, 2021
the bar links are quite easy (if no stripped bolts)
Old Jul 9, 2021
imhtwo's Avatar
Hey. The upper stabilizer bar was not stripped, the bolt was just missing. I spoke to the dealership this morning. They have taken responsibility for the loose stabilizer bar and replace the tire as well for free. Guess someone forgot to reconnect it while working on my AC.
Thanks for the responses.
Old Jul 10, 2021
imhtwo's Avatar
Picked the care up today. The dealership installed new stabilizer bar and a new tire for free. Apparently they did take the tire off to install the compressor and just didn't tighten the bolt on the stabilizer.
Now i get some belt squeaking, belt looks good will have to look into that now.
Old Jul 10, 2021
FRSam's Avatar
Click Here
Probably has something to do with the tension. Too loose in all likelihood
Old Jul 10, 2021
imhtwo's Avatar
Yea, I was going to go ahead and replace the belt, I am sure its about time. Hoping that resolves it.
Old Jul 11, 2021
Colin42's Avatar
Replace the tensioner as well
Old Jul 17, 2021
imhtwo's Avatar
I replaced the belt tensioner, idler pully and the belt today. Will see if that solves the squealing issue. I did notice that the arrow on the new tensioner was still right at the edge of the marking. Not sure if this matters as long as the squealing stops.
Old Jul 17, 2021
Colin42's Avatar
Is that mark for when you have the tensioner cranked all the way over to get the belt on and off? Or for when the tensioner isn't under load?
Old Jul 17, 2021
imhtwo's Avatar
That is a picture with everything installed (belt tensioner, idler pully and the new belt) under load. Its an auto tensioner so there is no adjusting it manually, the pic show where the arrow landed once everything was installed. I did just have the AC Compressor replaced by the dealership a little over a week ago as well. I assume the arrow should be in that square section when under load, if I was to take tension like i was going to remove the belt the arrow moves into that area.
Old Jul 17, 2021
Colin42's Avatar
Honda parts for the tensioner and belt or no?
Old Jul 17, 2021
imhtwo's Avatar
From what I can tell the OEM belt is discontinued But the belt and tensioner i purchased are CONTINENTAL brand..
David Pruitt
Aug 9, 2016 01:24 PM
ondalow01
Jul 4, 2009 09:15 PM
yellowgqthug817
Jan 31, 2006 01:22 PM
EM2Civic
Jun 13, 2004 07:59 PM
Pharoh
Jul 29, 2003 01:40 AM
