How much drain should AC cause?
Old Jul 27, 2003
Pharoh's Avatar
Bobaganoosh!
I just had my AC compressor changed for the 2nd time and now I have another problem with either the compressor or the Alternator....
There's a grinding under the hood that occurs under throttle increases and remains constant when the AC is turned on...Now, it could be the compressor again or the alternator from the added load caused by the AC. My volt meter took a huge dive when the AC was turned on and then quickly rebouded....
Any ideas???
Old Jul 28, 2003
My engine sounds terrible with the AC on. I think it's normal, since the AC has to draw alot of power and make the engine work harder.
Old Jul 29, 2003
CIVIC808's Avatar
CIVIC808 is an unknown quantity at this point
what happened to the first compressor?what was the voltage reading with the a/c on?does it make that noise when the a/c is off?im thinking its the compressor for the noise since you say it only does it when its on.voltage will drop when the a/c is turned on which is normal unless its really taking alot of juice.
Munzy
21
Oct 7, 2015 07:48 AM
Raiool
Oct 1, 2015 10:42 AM
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
General DIY
Sep 25, 2015 08:02 PM
