Air Conditioning Post issues about air conditioning here
Ac pressures equalized
Old Jun 5, 2021
Masonchamby's Avatar
Masonchamby is an unknown quantity at this point
OK so I just picked up a 2009 civic, I had to replace the AC relay and I went to test it. Immediately the car starts blowing warm air and then when I drive it above 45 miles an hour and blows cold air. Hooked up my gauges and I have 80 psi on the low side and 150 on the high side at idle! I don’t believe that it’s over charges and my suspicions are taking me towards a metering device issue. Has anyone had any other issues like this? Any help is appreciated .
and yes the Compressor does engage and the condenser fans do turn on when I turn on the AC.
Old Jun 7, 2021
BrotatoChip's Avatar
Super Moderator
Re: Ac pressures equalized
Sounds like possibly a failing compressor. Low side is too high to be running but doesn't appear to be overfilled. High side is too low but because of the low side reading means it's not underfilled. Compressor isn't building up enough pressure.
Old Jun 7, 2021
I originally thought that too, however the system was never fully charged to begin with. The compressor clutch is not stiff at all and it’s easy to turn. I actually had the AC relay go bad on me and had to replace it to. Something very interesting is that when the AC is turned off the pressures take about an hour to equalize.
Old Jun 7, 2021
Super Moderator
What does the pressure read when it has equalized? Should be around ambient temp in Fahrenheit. You say it wasn't ever fully filled but I'm the pressures are not saying it's low. If it were low on refrigerant you would see the high side too low (like it is) and the low side too low (like 10 psi).
Old Jun 7, 2021
the pressure is normally equalized out around 100 psi but it takes about an hour to do sound like I said. wha
Old Jun 7, 2021
Super Moderator
According to all the readings you've provided I can confidently say the system is not low. I still believe it is a failing compressor.
Old Jun 13, 2021
1sthonda09Civic's Avatar
1sthonda09Civic is an unknown quantity at this point
I'm going to follow this one because I too am having issues with an 09 Civic I recently purchased and maybe someone can also post some help for information on my issue.... mine starts out nice and cold no problem and at idle has 50 psi on the low side I didn't check the high side.... it will only go out after I take it on about a 10 minute drive and once I do that the compressor clutch shuts off... I verified that I do have power by putting a test lamp from negative to the red wire on the clutch, and also verified if I move the test light over to the positive cable and probe my ground or my hot wire that I do get the test light to come on..
is it possible the clutch just gets too hot and stops engaging, as I can visibly see that the clutch no longer is engaged?
Old Jun 13, 2021
Colin42's Avatar
Originally Posted by 1sthonda09Civic
I'm going to follow this one because I too am having issues with an 09 Civic I recently purchased and maybe someone can also post some help for information on my issue.... mine starts out nice and cold no problem and at idle has 50 psi on the low side I didn't check the high side.... it will only go out after I take it on about a 10 minute drive and once I do that the compressor clutch shuts off... I verified that I do have power by putting a test lamp from negative to the red wire on the clutch, and also verified if I move the test light over to the positive cable and probe my ground or my hot wire that I do get the test light to come on..is it possible the clutch just gets too hot and stops engaging, as I can visibly see that the clutch no longer is engaged?
​​​​​​​Could be, you can take apart the clutch and remove a shim, see if it engages better
Old Jun 13, 2021
I guess I could try that, the funny thing is the once I hit about 45 the AC turns ice cold.
Old Jun 13, 2021
Colin42's Avatar
Sorry that was to someone else, you need to do what Brotato told you to do
guitarsnlikker
Air Conditioning
Jul 14, 2019 11:54 AM
mrohitredd
May 30, 2015 06:51 PM
sdraza1
Sep 4, 2013 09:11 PM
civicbaby
Jul 15, 2011 11:38 AM
01civicexboy
Mar 20, 2006 10:46 AM
